Please help me understand this code
Results 1 to 15 of 15
    May 2009
    Montreal, QC, Canada
    Default Please help me understand this code
    From the code bellow, I am expecting to have the DEBUG line running only when the variable "ReadFlag" is set and it does, so far so good.
    But once it ran, I clear ReadFlag and it should become set again ONLY if I=10 and this should happen only after the Interrupt has ran 10 times right? Well it is not happening.
    In my DEBUG line "I" shows up as 0,2,4,5 randomly
    I am not using variable "I" anywhere else other than:
    I VAR BYTE
    I = 0
    at the top of my program.
    Can someone help me understand this?
    Goto main
        DO while readflag = 1
            debug dec Fvalue," i=",dec i," R=",dec readflag,10,13  ; Display on terminal if ReadFlag = 1
            readflag = 0            ; do not update until the next 10 readings
            Fvalue = 0
        LOOP
    '---[INT - interrupt handler]------Signal found at RB0, take a reading
    SignalFound:
        T1CON.0 = 0                             ; Stop timer1
        i = i + 1
        FValue = TMR1H * 256 + TMR1L + fvalue   ; Add 10 readings to FValue
        if i = 10 then
            fvalue = fvalue / 10                ; get the average of one reading
            i = 0                               ; Reset counter
            ReadFlag = 1                        ; FValue is ready to read
        TMR1H = 21                              ; reset timer1 to 60mS
        TMR1L = 167
        T1CON.0 = 1                             ; Start timer1
    @ INT_RETURN
    Mike
    May 2009
    Getting even more confusing, I tried:
    DO while I = 0
    And still the DEBUG line shows up even when: I > 0
    You probably have several timer interrupts while it's inside your DO LOOP, so I ends up with unexpected values.
    Example: With i = i + 1 being first in your timer interupt, it's changing the value of i on every interrupt, and sometimes even during the process of PBP trying to output everything with DEBUG.
    When DEBUG actually starts, your interrupt is still changing I before PBP outputs it.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Bombay, India
    Try this. Changes are in Bold
    SignalFound:
        i = i + 1
        if i >= 10 then                        ' COMPARISON CHANGED TO >=
            fvalue = fvalue / i                ; get the average of one reading CHANGED HERE
        TMR1L = 167
    @ INT_RETURN
    May 2009
    Hi Bruce and Jersen,
    That is really fast !
    Jerson,
    I was able to observe the proper values by moving the DEBUG line inside the INT handler.
    Is there a more efficient way to observe variables values within a program?
    It seams like LCDOUT and DEBUG are taking too long to operate and are giving false values.
    Thank you
    Mike
    May 2009
    Bruce,
    I came across this link you wrote Entitled "Using MicroCode Studio ICD
    With The PIC16F628 Microcontroller" http://www.rentron.com/PicBasic/MCS_X3.htm
    Would this enable me to view each step of a program as well as where the PIC timer is at while executing a specific line of code?
    Mike
    Hi Mike,
    Yep. MCS+ ICD is very handy if you have the paid version of MCS+. But if you're trying to view real-time timer values, I would go with MPLAB/MPSIM.
    By the time you LCDOUT, SEROUT, whatever, the timer is long past the value you're displaying.
    What precisely is it you need to do?
    -Bruce
    tech at rentron.com
    May 2009
    I didn't think I could see real time values with MPSIM using a program written with PBP!
    I will give it a try, I guess I have to invest a little time learning the Stimulus properly, I have done very little assembly and was able to test buttons triggering LEDs but when I started going deeper into this I kind of got distracted with PBP.
    I am building an ultrasonic distance measurement device, I have seen some circuits here and there but I really want to fully understand what I am doing and build my own. I don't have any code to show just yet because I have started to isolate the different parts of my code and it doesn't look like any program right now.
    What I am trying to achieve is using Daryl's Interrupts.
    Using TMR1_INT I send HPWM and using INT_INT I detect the echo from the Rx on RB0.
    I keep trying to tell myself that the PIC is running fast but I am always amazed with how much I underestimate the speed at witch it operates.
    I think I am not too far from something, just wish I could slow down everything and observe what is going on during each operation of code (other than the operation itself)
    I guess MPSIM is probably the way to go?
    Mike
    May 2009
    I got PBP running with MPSIM and now I finely see what is happening and when, thanks for this info.
    Mike
    May 2009
    I don't know what's going on here!
    Using MPSIM with watch window
    I have TIMER1 running, I can observe that TMR1H=218 and TMR1L=8
    testa is a word variable.
    I execute this operation:
    testa = TMR1H
    and I see that testa = 218
    Then I do this:
    testa = TMR1H * 256 + TMR1L
    However now testa = 8 instead of 55816
    What am I missing?
    PS: Sorry for mistyping Darrel's name in post #8, I know a Daryl and it just came out without thinking!
    Mike
    May 2009
    When I send the value of testa on a DEBUG line I get the proper value so it must be a setting in MPSIM somewhere.
    I can't figure out why there would be such a setting though!
    Mike
    Which PIC are you using?
    Some with 16-bit read/write modes for timers require you to read low byte first, then high byte.
    -Bruce
    tech at rentron.com
    May 2009
    I am using 16F628A
    In the Watch properties of testa I changed the size to 16 bits and that solved it.
    Now how can I get the value of each array data in the watch window?
    let say I have a variable called ArrayVariable(x)
    I would like to read ArrayVariable(1) and ArrayVariable(2)
    The only choice I get from the list is _ArrayVariable
    Mike
    Click View, File Registers, and scroll down until you see _ArrayVariable. This will be
    _ArrayVariable[0]. After that will be the rest of the array.
    -Bruce
    tech at rentron.com
    May 2009
    I am all set, thanks so much!
    Mike
