Writing PBP Commands/macros
Results 1 to 6 of 6
    Without seeing your function it's hard to tell what's wrong, but it's easy to pass numeric values.
    Try something like this;
    PIN   VAR BYTE BANKA SYSTEM ' system vars in access ram
    TIME  VAR WORD BANKA SYSTEM
    NUMS  VAR BYTE BANKA SYSTEM
    LOOPS VAR BYTE
    X     VAR BYTE
    PULSE MACRO PinToPulse,TimeToPulse,NumberOfLoops
          MOVLW   PinToPulse
          MOVWF   PIN
          MOVLW   LOW TimeToPulse
          MOVWF   TIME
          MOVLW   HIGH TimeToPulse
          MOVWF   TIME+1
          MOVLW   NumberOfLoops
          MOVWF   NUMS
          CALL    _DOPULSE
        ENDM
    MAIN:
        @ PULSE 0,256,10 ; Pulse RB0, pause 256mS, 10 times
        PAUSE 1000
        GOTO MAIN
    DOPULSE:
        FOR LOOPS = 1 TO NUMS
         HIGH PIN
         PAUSE TIME
         LOW PIN
         PAUSE TIME
        NEXT LOOPS
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jul 2009
    Hi Bruce, thanks for the reply,
    I use the following code and INCLUDE it in my main PBP file:
    ' Constants
    CONTROL_BYTE con $40    ' write operation to device address $00
    ' Port Expander Registers
    IOCON con $0A
    IODIRA CON $00
    IODIRB CON $01
    GPIOA CON $14
    GPIOB con $15
    ' Pin Definitions
    SCLK var PORTC.3
    SDI var PORTC.4
    SDO var PORTC.5
    nCS var PORTA.2
    nRST var PORTA.3
    REGISTER_BYTE var byte
    DATA_BYTE var byte
    goto EndOfPortExpander
    ' Macros
    asm
    PE_Init_As_Outputs macro                   ; Send appropriate initialisation bytes for Outputs
        L?CALL _PE_INITIALISE_OUTPUTS
    PE_Write macro Data, Register   ; Write Data to the Port Expander Register
        MOVLW   Data
        MOVWF   _DATA_BYTE
        MOVLW   Data
        MOVWF   PORTB
        MOVLW   Register
        MOVWF   _REGISTER_BYTE
        L?CALL _SEND_PE_BYTE
    endasm
    ' Subs
    PE_INITIALISE_OUTPUTS:
            nRST = 0 ' reset the port expander
            pause 10
            nRST = 1
            REGISTER_BYTE = IOCON
            DATA_BYTE = %00100000
            gosub SEND_PE_BYTE       ' setup IOCON for Bank 0 non-sequetial operation
            REGISTER_BYTE = IODIRA
            DATA_BYTE = $00
            gosub SEND_PE_BYTE       ' set PORTA as output
            REGISTER_BYTE = IODIRB
            DATA_BYTE = $00
            gosub SEND_PE_BYTE       ' set PORTB as output
    SEND_PE_BYTE:
            nCS = 0 ' enable PE
            Shiftout SDO, SCLK, 1, [CONTROL_BYTE,REGISTER_BYTE,DATA_BYTE]
            nCS = 1 '
            pause 10
    EndOfPortExpander:
    The problem I am having is when invoking the PE_WRITE macro. To check what is being passed to the macro I am writing Data to PORTB. When I invoke the following:
    @   PE_Write 55h, _GPIOA
    I get 55h on PORTB - it works correctly. However when I call the following:
    Temp VAR BYTE
    Temp = $55
    @   PE_Write _Temp, _GPIOA
    I get 22h on PORTB. I have tried other numbers for Temp but they all show 22h on PORTB.
    I can only think that this is some kind of type mismatch but I don't see how. Any ideas?
    MOVLW 55h moves the literal value of 55h into W.
    MOVLW _Temp loads the address of _Temp into W. If you look at the .lst file you'll
    see _Temp is located at 22h in RAM.
    _Temp is a file register. If you want the value in _Temp in W use MOVF _Temp,W.
    -Bruce
    tech at rentron.com
    Ditto what Bruce said.
    But I would add ...
    When working at the ASM level, everything is just Numbers.
    The assembler doesn't know anything about Byte Word or Long variables.
    And it has no way of knowing if you passed it a constant, variable or your birthday.
    If you pass a constant, the number is the value of the constant.
    Passing a variable, will give the starting address of that variable in RAM.
    Passing a Label, will give the address to a piece of code in Flash.
    They are all just numbers, and it's up to you to handle them properly.
    If you look through PBP's .mac files, you'll see that there is a different macro for each possibility of inputs.
    LCDOUT?C ; expects to be passed a constant.
    LCDOUT?B ; will work with a byte variable
    ... the other vars each have their own LCDOUT macro ...
    The ?CB suffix indicates the type of input, in PBP they are ...
    A = W register (Accumulator)
    C = Constant
    B = Byte variable
    W = Word variable
    N = Long variable
    T = Bit variable
    Placing the suffix there, doesn't do anything by itself, it's just an easy way to recognize which macro you need to use, depending on the type of inputs you have.
    With your PE_Write macro, there should be at least 4 versions.
    And keeping with the PBP syntax, they might be called ...
    ;             :   Data,     Register
    PE_Write?CC   ; Constant,   Constant
    PE_Write?CB   ; Constant,   Byte
    PE_Write?BC   ; Byte,       Constant
    PE_Write?BB   ; Byte,       Byte
    Fortunately, PBP already has all the macros you need to move the different values around, so you don't really need to do MOVF, MOVWF, etc ... and those macro's will handle all the Banking issues that are difficult to manage with MOVF type instructions.
    Those Macro's have the Name of MOVE?, and use the same suffixes shown above.
    So the first macro using two constants would look like ...
    PE_Write?CC   macro Data, Register
        MOVE?CB  Data, _DATA_BYTE
        MOVE?CB  Data, PORTB
        MOVE?CB  Register, _REGISTER_BYTE
    The second macro with a constant Data, and Byte Register
    PE_Write?CB   macro Data, Register
        MOVE?CB  Data, PORTB
        MOVE?BB  Register, _REGISTER_BYTE
    Note that there is only one character different between the last two code sections (in blue).
    The third macro ... Byte Data, Constant register ...
    PE_Write?BC   macro Data, Register
        MOVE?BB  Data, _DATA_BYTE
        MOVE?BB  Data, PORTB
    And the forth ... Byte Data, Byte register ...
    PE_Write?BB   macro Data, Register
        MOVE?BB  Data, PORTB
    You can probably see that if you consider ALL the possibilities, there's a lot of macros to write for a single function.
    To use them, simply choose the macro that fits your inputs...
    @  PE_Write?CC   55h, _GPIOA
    Temp = $55
    @  PE_Write?BC   _Temp, _GPIOA
    Reg = GPIOA
    @  PE_Write?BB   _Temp, _Reg
    HTH,
    Jul 2009
    Bruce,
    Thanks for the reply, looks like I have fallen foul of the curse of high level languages and forgotten all my assembler! I will have to go and brush up I think!:-D
    Darrell,
    Thanks also, I had seen the ?CB notation in your LCD Bargraphs but couldn't find any reference to it with google. I have now got my macros working nicely, thankyou.
    I am guessing that since "everything is just numbers" there is no clever way to tidy it up and automatically detect what you have passed the macro?
    Andy
