after all ... PBP is not so bad ...
Results 1 to 24 of 24
    Sep 2007
    USA, CA
    What was the "other" compiler? I have PBP, but switched my primary compiler to Proton because I was running out of room on a project. It wouldn't fit with PBP, but it would with Proton. In fact, I saved about 20% with with switch... I had room for feature creep!
    Apr 2003
    Cambridge - UK
    the Goal : read a voltage and display it as a heading ( boat autopilot app. ) and use a 16F819
    Result is astonishing :
    Another Basiç compiler ... 2504 Words ... The ' 819 is unusable !!!
    its " PRO " version ..... 1722 Words ...
    PicBasicPro ... ahaaaaa ...514 Words.
    Of course I can prove the test is true and honest ...
    Please publish your code example and name the compilers that you used. or your post leaves the reader to rely on innuendo and speculation.
    If your code example is valid and the compilers are genuine versions and have been used correctly, there is nothing to gain by not mentioning the names of the compilers that you tested.
    AS a moderator, you must make the effort to set a good example, when making a post on a subject that is obviously going to stor up some emotive discussion.
    Furter, if your comparisoons are valid, your post could easily become the core of an article in the WIKI or even an article in the catalogue section where we advertise and promote PBPro.
    Come on, you can do better, if the jobs worth doing, do it well. If you're going to promote PBPro in this way, lets see it done openly with transparency.
    Last edited by Acetronics2; - 1st May 2010 at 11:54. Reason: Lester's special request ....
    Alain,
    That all is interesting but I have a question.
    Why did you modify someones post to post your test?
    I always hate it when a post has a major edit because there is not any notification of the edit. Doing a major edit to another s post is really out there.
    Default Just for you Dave ...
    As requested ...
    want proof ??? Ok ... let's go !
    1St attempt : Mikrobasic 7.2 ...
    program Gouvernail        ' program PiloteAT50
     ' microcontroleur : 16F819 sur EasyPic 5
    ' Projet : PPE 2010
    ' En entree : A0 Up3 = entree analogique
     ' En sortie : portB Affichage des consignes "Babord et Tribord" sur lcd
     'program PiloteAT50
     symbol Up3 = PORTA.0 ' tension analogique (<5V)
    ' déclaration des variables
     dim result  as word
     dim tension as longint
     dim angle   as longint
     dim text    as string[9]
     dim valeur  as string[11]
     const Vref = 5000
     sub Procedure Init ' Initialisation
     'CMCON = 7
     trisb = %00000000 ' portB en sortie
     trisa = %11111111 ' portA en entrée
    Delay_ms(500)
    Lcd_Config(PORTB, 3, 2, 1, 0, PORTB, 4, 6, 5) ' Initialize LCD connected to PORTB
     'LCD_init(PORTB) ' initialisation Lcd sur PortB
     Lcd_Cmd(lcd_Clear)
     Lcd_Cmd(lcd_cursor_off)
     end sub
     main: ' ********* Principal *********
     Init ' config. et init. du PIC
     while true ' début de la boucle
         result = adc_read(0)
         tension = result *  Vref /1024  ' en mv !!!
         ' < ou > 4.02 v ???    ( 1024 * 4.02/5 = 823 !!! )
         if tension < 4020 then
            text = " Tribord "
            Text = "  Babord "
         end if
     ' Calcul de l'angle
            angle = 3133 * Fabs(tension - 4020) / 120000
     ' Affichage
            LongintTostr(angle,valeur)
            Lcd_out(1, 1, text)
            Lcd_out(2,1,valeur)
             delay_ms(100)
     wend
    end.
    1:1 E-0 Linker error: NOT ENOUGH ROM
    NOTA: 2504 Words compiled for a 16F877A
    2nd Attempt : MikroBasic 7.2 ... NOT USING Fabs () ... = PbP ABS()
     ' microcontroleur : 16F877A sur EasyPic 5
    ' Projet : PPE 2010
     'program PiloteAT50
     dim result  as word
     const Vref = 5000
    ' CMCON = 7
    Delay_ms(500)
     Lcd_Cmd(lcd_Clear)
     end sub
            text = " Tribord "
            angle = 3133 * (4020 - tension ) / 120000
            Text = "  Babord "
            angle = 3133 * (tension - 4020) / 120000
         end if
     ' Calcul de l'angle
    '        angle = 3133 * Fabs(tension - 4020) / 120000
     ' Affichage
            Lcd_out(1, 1, text)
            Lcd_out(2,1,valeur)
             delay_ms(100)
     wend
    end.
    0:0 S-100 Success (Release build) - Timestamp: 10:15:57
    0:0 W-101 Used ROM: 1774 (86%) Used RAM: 80 (31%)
    0:0 W-102 Free ROM: 273 (14%) Free RAM: 176 (69%)
    a small bit better ...
    3rd attempt : MikroBasic PRO 3.2
    program Gouvernail
    ' Projet : PPE 2010
     'program PiloteAT50
     ' Lcd module connections
    dim LCD_RS as sbit  at RB4_bit
        LCD_EN as sbit  at RB5_bit
        LCD_D4 as sbit  at RB0_bit
        LCD_D5 as sbit  at RB1_bit
        LCD_D6 as sbit  at RB2_bit
        LCD_D7 as sbit  at RB3_bit
        LCD_RS_Direction as sbit at TRISB4_bit
        LCD_EN_Direction as sbit at TRISB5_bit
        LCD_D4_Direction as sbit at TRISB0_bit
        LCD_D5_Direction as sbit at TRISB1_bit
        LCD_D6_Direction as sbit at TRISB2_bit
        LCD_D7_Direction as sbit at TRISB3_bit
    ' End Lcd module connections
    ' Symbol Up3 = PORTA.0 ' tension analogique (<5V)
     dim resulta  as word
     const Vref = 5000
    ' Init ' config. et init. du PIC
    ' CMCON = 7
    Delay_ms(500)
    'Lcd_Config(PORTB, 3, 2, 1, 0, PORTB, 4, 6, 5) ' Initialize LCD connected to PORTB
     LCD_init() ' initialisation Lcd sur PortB
     Lcd_Cmd(_LCD_CLEAR)
     Lcd_Cmd(_Lcd_Cursor_Off)
           resulta = adc_read(0)
           tension = resulta *  Vref /1024  ' en mv !!!
              text = " Tribord "
               ' Calcul de l'angle
               angle = 3133 * ( 4020 - tension ) / 120000
              Text = "  Babord "
           end if
       ' Affichage
              Lcd_out(1, 1, text)
              Lcd_out(2,1,valeur)
               delay_ms(100)
    wend
    end.
    0 133 Compiled Successfully C:\Program Files\Mikroelektronika\ProjetsBPro\Gouvernail\Gouv ernail.mbas
    0 1143 Used ROM (program words): 1722 (84%) Free ROM (program words): 326 (16%)
    0 1143 Used RAM (bytes): 44 (18%) Free RAM (bytes): 196 (82%)
    a tiny little bit better ...
    4Th attempt : Our favourite PicBasicPro v 2.60 / MPASM/ MCS ( left MkB lines commented besides PbP lines ...)
    '*  Notice  : Copyright (c) 2010 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 30/04/2010                                        *
    'program Gouvernail        ' program PiloteAT50
    ' Projet : PPE 2010
     'program PiloteAT50
    @ ERRORLEVEL -306
    @ __config _HS_OSC & _WDT_ON & _PWRTE_ON & _BODEN_ON & _LVP_OFF & _CP_OFF
     entree var PORTA.0 ' tension analogique (<5V)
    ' dim result  as word
    ' dim tension as longint
    ' dim angle   as longint
    ' dim text    as string[9]
    ' dim valeur  as string[10]
    ' const Vref = 5000
    result var word
    tension var word
    angle var word
    dummy var word
    vref con 5000
     'sub Procedure Init ' Initialisation
    DEFINE  OSC 8
    CLEAR
    ;----[LCD definitions]------------------------------------------------------
    DEFINE LCD_DREG  PORTB          ' LCD Data port
    DEFINE LCD_DBIT  0              ' starting Data bit (0 or 4)
    DEFINE LCD_EREG  PORTB          ' LCD Enable port
    DEFINE LCD_EBIT  5              ' Enable bit  (on EasyPIC 5 LCD)
    DEFINE LCD_RSREG PORTB          ' LCD Register Select port
    DEFINE LCD_RSBIT 4              ' Register Select bit   (on EasyPIC 5 LCD)
    DEFINE LCD_BITS  4              ' LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 2              ' number of lines on LCD
    DEFINE LCD_COMMANDUS 2000       ' Command delay time in us
    DEFINE LCD_DATAUS 50            ' Data delay time in us
    DEFINE ADC_BITS 10 ' set number of bits in result
    DEFINE ADC_CLOCK 3 ' set clock source
    ADCON1 = %10000000  ' right formatted
    ' CMCON = 7
    'Delay_ms(500)
    PAUSE 500
    ' Lcd_Cmd(lcd_Clear)
    ' Lcd_Cmd(lcd_cursor_off)
    LCDOUT $FE,1
    ' end sub
     'while true ' début de la boucle
     while 1=1
    '     result = adc_read(0)
        adcin 0, result
         dummy = result * Vref
         tension = DIV32 1024  ' en mv !!!
            LCDOUT $FE,2, " Tribord "
            LCDOUT $FE,2, "  Babord "
     ' Calcul de l'angle
    '        angle = 3133 * abs(tension - 4020) / 120 / 1000
            dummy = 3133 * abs(tension - 4020)
            angle = DIV32 12000
            angle = angle /10
     ' Affichage
    '        LongintTostr(angle,valeur)
    '        Lcd_out(1, 1, text)
    '        Lcd_out(2,1,valeur)
            LCDOUT $FE, $C0, dec3 angle
    '         delay_ms(100)
              PAUSE 100
     wend
    Success ; 461 Words ...
    Really astonishing for such a simple work !!!, don't you think ???
    PS; as we are under the 2K limit EVERYONE can verify it with the Demo available versions of MikroBasic and MikroBasic Pro ...
    Sep 2007
    USA, CA
    That is quite good. PDS only gets it down to 457, with 25 variables used.
    (PBP uses 32 variable bytes.) Where PDS really shines, however, is when the file gets very large, when you use interrupts (it's built in; Darrel's utility is not needed), and with great implementation of mixing words and longs.
    May 2007
    Might be interesting if you would post your findings over at the mikroE forums.
    I do think it would be a very bad idea ...
    totally unfair, overall ...
    much too wide a gap !!! , don't you think ???
