PBPL (Long version) + HPWM?
Results 1 to 6 of 6
    May 2009
    Montreal, QC, Canada
    Default PBPL (Long version) + HPWM?
    Could someone please clarify?
    In the PBP manual at section 3.1- Usage it indicates:
    "PBPL can only be used with the PIC18 devices"
    In section 5.33 - PWM it indicates:
    "For the non-long versions of PBP (PBP and PBPW), the highest frequency at any oscillator speed is 32767Hz.
    I am using a 16F628A
    Sending to the PIC this command:
    HPWM 1,127,40000
    Looking at the scope I observe 40.1KHz (close enough)
    So does this mean there is a mistake in the manual? or does it mean I will burn my PIC shortly if I continue running at this frequency?
    Mike
    May 2009
    I guess that's a hard one to answer!
    I see that PBP lets me go up to 65,535 however having a value of greater than 62000 the frequency goes down. Which I can understand with a 4MHz OSC.
    I had the circuit running since yesterday with:
    HPWM 1,127,60000
    Which gives 62.7KHz and it is still going so I will stick with the possibility that there is a mistake in the PBP manual unless someone comes up with a better explanation.
    I am using 2.60 and manual is dated 6/09.
    Mike
    May 2009
    I am sorry to bring this up again but no replies from anyone is affecting my sleep.
    I just need to be reassured with a confirmation that HPWM does go way past the 32767 Hz with a 16F628A contrary to what is indicated in the latest PBP book. V2.60
    Because I keep reading threads about this limit that are suggesting that a miracle is happening on my bench.
    I have reduced my code to this and I am reading 40.1 KHz on the scope.
    @ __config _XT_OSC & _WDT_OFF & _MCLRE_ON & _LVP_OFF & _CP_OFF
    TRISA = $07
    TRISB = $05
    CMCON = $06
    INTCON = $10
    OPTION_REG = $C0
    HPWM 1,127,40000
    MAIN:
        pause 1
    GOTO MAIN
    May 2007
    Depending on the resolution required and by setting the CCP registers manually, the hardware is capable of running up into the MHz region.
    May 2009
    I have updated my code to this:
    CLEAR
    TRISB = $05
    CMCON = $07
    HPWM 1,127,40000
    MAIN:
        pause 1
    GOTO MAIN
    I still get 40.1KHz and I have not affected CCP registers manually
    May 2007
    When working with hardware peripherals (such as CCP/PWM, USART, etc.) I will set up the registers manually - that way I know exactly what the peripheral is doing. You will also save a significant amount of code space by not having the compiler/device perform what can sometimes be pretty math intensive operations.
