GSM modem not working with PIC! Both modem & PIC work fine with PC
Results 1 to 12 of 12
    Although I am sure it works on PC with just TX, RX nd Gnd, have tried to connect to PC just with these 3 wires?
    Also are you sure about 4800 baud?
    I tried it now, I could not type in my hyperterminal anymore as soon as I connected my modem to the PC with only 3 wires. As soon as I connected 9 pin serial cable, everything starts working fine.
    Yes, baud rate is 4800.
    ___________________
    WHY things get boring when they work just fine?
    May 2008
    Italy
    Was hyperterminal in hand shaking mode?
    See the modem manual, if the modem is in handshaking mode by default, in such a case you have to set it for no flux controll.
    Al.
    Question
    Quote Originally Posted by aratti View Post
    Al.
    I have not got the manual but I have opened the modem and saw that sim300 is the module which the modem is built on. I have checked sim300 datasheet but could not understand many things as I do not have too much of a technical background.
    Can you advise me, what AT commands can do this job.
    I also find this on the net - http://www.london-electronics.com/alpha_232_conns.gif
    Is this an alternate way to go to solve this problem (RTC - CTS connected together & also pins 6,1,4 connected together? I do not want to try it unless it is safe to do so, only have 1 modem
    Also, how can I find out if Hyperterminal is in Handshaking mode? One more thing I would like to mention here which I read from sim300 datasheet is that the modem supports and by default has Autobaud from 1200 to 19200.
    ___________________
    May 2008
    Italy
    When you set the baud rate you can set also the flow mode. See the three snaps attached.
    Al.
    Al.
    No, the handshake mode is "None".
    ___________________
    The setting of hyperterminal may not tell you whether the modem itself needs flow control . Typically if flow control is turned off, the RTS pin is set "high".
    One thing you can try is either to set no flow contol on the SIM300(if you can), or wire an output RS232 buffer to pin 7 of the serial cable and pull the input low, which should make the RTS active on the SIM300.
    Tim Barr
