Please help me understand this code
Results 1 to 15 of 15
    May 2009
    Montreal, QC, Canada
    When I send the value of testa on a DEBUG line I get the proper value so it must be a setting in MPSIM somewhere.
    I can't figure out why there would be such a setting though!
    Mike
    Which PIC are you using?
    Some with 16-bit read/write modes for timers require you to read low byte first, then high byte.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    May 2009
    I am using 16F628A
    In the Watch properties of testa I changed the size to 16 bits and that solved it.
    Now how can I get the value of each array data in the watch window?
    let say I have a variable called ArrayVariable(x)
    I would like to read ArrayVariable(1) and ArrayVariable(2)
    The only choice I get from the list is _ArrayVariable
    Mike
    Click View, File Registers, and scroll down until you see _ArrayVariable. This will be
    _ArrayVariable[0]. After that will be the rest of the array.
    -Bruce
    tech at rentron.com
    May 2009
    I am all set, thanks so much!
    Mike
