Comunication between 12F683 & 16F84A with serin2/serout2
Results 1 to 11 of 11
    Lightbulb
    Hi, Kklim
    could you " twist" somewhat the OSCTUNE register of the 683 ??? ... just to get a precise match with the '84 oscillator frequency ...
    may be just use the " blinky led " program and trim the 683 osc frequency to that you've measured on the '84 ...
    internal osc is " not so good " if you need frequ. matching ...
    Try changing serout2 datain,813,["B",dec tmp] to serout2 datain,813,["B", tmp]
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Apr 2010
    Hi all,
    I capture 2 waveform with a scope from 84A to 84A which work fine and 683 to 84A (no data) and Alain is correct, 683 waveform is shorter (Faster) then the 84A, after playing with the OSCTUNE, every 10 data send, only 1 data is show on the LCD. Also try change the Baud Rate from 813 to 1646 & 188, no data show.
    Looks like device with internal clock is no good for sending data to a device with external clock
    Quote Originally Posted by kklim29 View Post
    Hi all,
    So, I'm afraid you have to turn to a 16F88 or equ. 14 pins device ... ( 16F684? )
