The Screamer bootloader and LCDout
Results 1 to 7 of 7
    ice's Avatar
    ice Guest
    Default The Screamer bootloader and LCDout
    Hello,
    I am able to run simple programs like blink an LED using the
    DEFINE LOADER_USED 1
    and the Screamer bootloader http://www.sparkfun.com/tutorial/Bloader/bloader.htm
    The bootloadr states thatthe initial line has to be
    org 0x0004, which the DEFINE LOADER_USED 1 seems to do
    However the moment i put a line such as LCDout in my program,
    the screamer REFUSES to load it into the pic
    My other programs[which are in asm] run smoothly with the bootloader,even my serial routines.
    any idea whats going on here
    I also tried the microchipc bootmloader.The problem is,the loader downloads it to the chip,but the program doesnt start at all
    Help me out here please.
    -ice
    do you load the bootloader .Hex file into your PIC before?
    If so, i can't help BUT i'll really recommend you the MicroCode Studio Bootloader comming with the full version... that will solve all your problems.
    ice's Avatar
    ice Guest
    yes i did,
    The serial test routines that are bundled with the loader also work well
    -ice
    PBP always inserts a goto INIT at location 0. Normally this is all PBP will
    insert from locations 0 - 3 if you use DEFINE LOADER_USED 1 to force the ORG 4.
    Here's an example of what happens with DEFINE LOADER_USED 1
    ORG 0 ; Reset vector at 0
    goto INIT ; Finish initialization <-- a PBP thing for initialization
    ORG 4 ; Make sure no library code in first 4 loc
    When you use the LCDOUT command with PBP, it inserts clrf FLAGS before goto INIT.
    Here's what it looks like.
    clrf FLAGS ; Clear all flags on reset
    FLAGS is a system variable used by PBP, and it only gets inserted before goto INIT when using the LCDOUT command.
    Here's what you can do to fix it to work with the Bloader software.
    Open the PBPPIC14.LIB file and look for this section. Comment out clrf FLAGS as shown below. Save the library file.
    ;* Startup Code                                                     *
    ;* Input      : None                                                 *
    ;* Output     : None                                                *
    ;* Notes      : Must be first library routine.                  *
    ; <<other stuff snipped out here>>
      LIST
      NOLIST
        ifdef ICD_USED
      LIST
            nop                     ; Skip first location for ICD
      NOLIST
        ifdef FLAGS_USED
      LIST
        ;    clrf    FLAGS           ; Clear all flags on reset <----- COMMENT OUT
      NOLIST
    If you use the LCDOUT command then clear FLAGS in the begining of your PBP code. This instruction should be the first code executed.
    FLAGS=0
    That's it. The clrf FLAGS will not be automatically inserted at location 0, and your PBP programs will work with the Bloader software as-is.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    ice's Avatar
    ice Guest
    Thanks alot Bruce,
    your reply for explantory,ill try tht tday
    BTW,i reloaded the microchip Bootloader V9 and all my PBP programs work well with it including LCDOUT
    i was working on the V2 of the loader.
    Thank you once again.
    -ice
    bartleph's Avatar
    bartleph Guest
    Default BootLoaders and 16F877
    I wonder if anyone can help please:-
    I'm trying to use the PicLoader Bootloader. I have PICBASIC PRO Ver 2.30.
    How do I stop my Program from writing over the BootLoader vector...I've seen Bruce's reply further up where he says to modify the PBPPIC14.LIB file to stop the LCD clrf Flags from causing a problem, and I've done that. Should I be using DEFINE ONINT_USED 1 or
    DEFINE LOADER_USED 1 with this version of PicBasic Pro?
    Any help appreciated....Thanks Paul
    Quote Originally Posted by bartleph
    Yes. DEFINE ONINT_USED 1 was used for PBP versions prior to 2.33. Later versions use DEFINE LOADER_USED 1.
    -Bruce
    tech at rentron.com
  1. bootloader Freqout problems
    By handgio in forum mel PIC BASIC Pro
    Last Post: - 5th December 2007, 14:38
  2. help!! With Keypad change
    By clare1 in forum mel PIC BASIC Pro
    Last Post: - 12th December 2006, 22:13
  3. Help with me labs Bootloader
    By teknoman2420 in forum mel PIC BASIC Pro
    Last Post: - 20th August 2006, 10:37
  4. Alfat Sd/mmc
    By eoasap in forum mel PIC BASIC Pro
    Last Post: - 24th July 2006, 07:10
  5. LCDout Command causes Interrupt!!??
    Last Post: - 31st March 2005, 05:18
