Help! - Very strange results with ShiftIn/ShiftOut
Results 1 to 4 of 4
    Default Help! - Very strange results with ShiftIn/ShiftOut
    I am running a 16F876 at 20MHz. I am reading a channel on an AD converter (Texas Instruments TLC2543) using the shiftin/shiftout commands and then sending the results to a serial port at 38400. The simple code is shown below. The code works fine as long as the Pause 4 is being used. If I remove the Pause 4 or make it lower than 4 ms, the variable 'result' is zero instead of 2544 or what have you. When I check the voltages at my voltage pin (PORTC.3) which is powering the sensor and ad converter, the pin reads 0 volts when the "PAUSE 4" is not used and when the "PAUSE 4" is used it goes to 5 volts. Now that's weird. The reason I'm getting a zero in the result is because the power pin mysteriously goes to zero as if there is a short or something.
    I thought it was perhaps the AD converter being slow but I cancelled this theory when I found I can loop through the converter 20 times and take an average and there is no problem as long as I use the "PAUSE 4" before entering the ReadAD subroutine, looping within the subroutine 20 times and then exiting. If I put the "PAUSE 4" after the ReadAD Subroutine I get zeros. The "PAUSE 4" has to be done before the ReadAD Subroutine. It's really bizzare.
    If anyone has some insight into this I would sure appreciate it.
    Kind Regards,
    Eric
    clear ' clear the variables
    High SensorPower
    MainLoop:
    Pause 4
    ADch = TiltX
    gosub ReadAD
    serout2 TX, 6, [Dec result, 13, 10]
    goto MainLoop
    ' read the AD converter
    ReadAD:
    High SensorPower
    LOW ADcs ' select chip
    SHIFTOUT sdo,sclk,MSBFIRST,[ADch<<8\12] ' mode, left justify ADch
    SHIFTIN sdi,sclk,MSBPRE,[result\12] ' get result, 12 bits
    HIGH ADcs ' deselect chip
    what about if you disable your a/d at the begining of your program HIGH ADcs ... don't forget all pins are supposed to be low at the begining so your adc consider that he is enable.
    BUT chances are that you don't set the TRIS for your adc, in this case, the ADcs pin is set as an input and floating. It this case, it can give enough highlevel signal to disable your ADC... this why your PAUSE 4 is handy in your case.
    I'm really not sure if it's a good practice to use bit shift in a SHIFTOUT statement.
    AND some a/d may need few mSec pause between SHIFTOUT and SHIFTIN... let the time to convert properly. Pause 10 can be good... see your a/d datasheet for that issue.
    Hi khufumen,
    I think the problem here is that the TLC2543 sends the previous result OUT at the same time the next address is clocked IN to start a conversion.
    The SHIFTIN and SHIFTOUT statements can't do both at the same time. Add in the Conversion Time that overlaps into the next SHIFTIN, and the 2 chips get out of Sync when the 12-bits don't match up.
    If you don't mind getting only every other sample, you can do it but there are a couple of timing issues.
    Do the SHIFTIN first, this will get the results of the last conversion. At the same time it will start a conversion of Channel 0.
    Wait at least 10us for the conversion to complete. (double that for safety)
    Now, do the SHIFTOUT to start the next Conversion with the desired channel, and exit the subroutine.
    Essentialy, you're starting a dummy conversion when Reading, and discarding the results when Writing to the device.
    High SensorPower
    ADch = TiltX  ' First AD reading will be garbage
    gosub ReadAD  '  but it also starts the next conversion
    MainLoop:
        ADch = TiltX
        gosub ReadAD
        goto MainLoop
    ReadAD:
        High SensorPower
        LOW sdo                                 ' send all 0's during read
        PauseUS  20                             '  wait for conversion to finish
        SHIFTOUT sdo,sclk,MSBFIRST,[ADch<<8\12] ' Start next conversion
    If you wanted to write you're own SHIFTIN/OUT routine, you could catch every sample by sending data in both directions at the same time. It would also be much faster. Since PBP's SHIFTOUT operates at somewhere around 50khz, it takes 240uS just to send the instruction to start a conversion, and another 240uS to read the result. If done manually, you should be able to get up to 400khz or more. That would SHIFTOUT 12 bits in 30uS.
    HTH,
    &nbsp;&nbsp;&nbsp;Darrel
    Default Finally figured out problem
    Thanks for all your help and input. What was causing the problem was that there was no delay between when I powered up the AD converter and when I started reading from the AD converter. The AD converter when powered up needs about 4 ms to stabilize before it can be read from. Once it stabilizes, it has no problem reading the the data.
    The fixed code reads:
    High SensorPower ' power up the sensors and the AD converter
    Pause 4 ' wait for power to stabilize
    MainLoop: ' enter main loop
    ADch = TiltX
    gosub ReadAD
    goto MainLoop
    ReadAD:
  1. RC - connection using RCTime produces strange results
    By selbstdual in forum mel PIC BASIC Pro
    Last Post: - 8th February 2007, 16:16
  2. Searches
    By bearpawz in forum Forum Requests
    Last Post: - 7th November 2005, 18:47
  3. Strange Results in Math
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 07:09
  4. First test program, but strange results
    By bartman in forum General
    Last Post: - 19th November 2004, 03:14
  5. I'm getting strange Results using POT or RCTIME on PortB (or GPIO Port)
    Last Post: - 15th July 2004, 20:01
