PWM=on...DEBUG=off
Results 1 to 5 of 5
    Exclamation PWM=on...DEBUG=off
    Hi guys,
    i'm building a project to test piezos and check what is the best working frequency.
    I'm using a 12F615 and the code is very simple:
    send frequency out using HPWM and when the sound from the piezo sounds about right and pressing a switch the frequency value will output via RS232.
    The problem i'm having is that when activating HPWM the debug function does not work.
    If i remove the bold definitions ( see below ) the debug works.
    [code]
    DEFINE OSC 8
    OSCTUNE=%0000000
    @ DEVICE PIC12F615, INTRC_OSC_NOCLKOUT
    @ DEVICE PIC12F615, WDT_OFF
    @ DEVICE PIC12F615, PWRT_OFF
    @ DEVICE PIC12F615, MCLR_OFF
    @ DEVICE PIC12F615, BOD_OFF
    @ DEVICE PIC12F615, PROTECT_ON
    @ DEVICE PIC12F615, IOSCFS_8MHZ
    '************************************************* *****************ADCON0=0
    ANSEL=0
    WPU=0 ' Disable pull-ups
    CMCON0.7=0 ' Turn off comparator
    INTCON=0 ' Interrupt control register
    OPTION_REG.7=1 ' Disable Pull-Ups
    OPTION_REG.3=1 ' Disable Pull-Ups
    CCP1CON=%10001100 ' PWM mode; P1A active-high; P1B active-high
    PWM1CON=%10000001 ' min dead-band time
    T2CON.2=0
    T1CON.3=0
    VRCON=0 ' Internal Vref disabled
    TRISIO=%011001
    GPIO=0
    'PINS
    sw1 var GPIO.0 'stop switch
    out var GPIO.1 'OUT PIN for debug
    piezo var GPIO.2 'output pwm
    in var GPIO.3 'Input
    sw2 var GPIO.4 'spare switch
    Led var GPIO.5 'Led
    PI1 var word
    na var word
    duty VAR WORD
    freq var word
    Include "modedefs.bas" ' Include serial modes
    DEFINE DEBUG_REG GPIO
    DEFINE DEBUG_BIT 1
    DEFINE DEBUG_BAUD 9600
    DEFINE DEBUG_MODE 1
    'PWM
    DEFINE CCP1_REG GPIO 'Hpwm 1 pin port
    DEFINE CCP1_BIT 2 'Hpwm 1 pin bit
    INIT:
    high out
    debug $0D, $0A
    PAUSE 50
    debug "Starting...",13,10
    debug 13,10
    low led
    Duty = 127 '50% duty
    debug "started frequency loop",13,10
    start:
    debug 13,10
    debug 13,10
    low led
    for freq=2000 to 4000 step 10
    HPWM 1,duty,freq
    debug dec freq,13,10
    debug 13,10
    pause 50
    if sw1=1 then
    while sw1=1
    wend
    goto play
    next
    high led
    pause 300
    goto start
    play:
    debug "freq=",dec freq,13,10
    [code\]
    Any help would be appreciated
    Hi there,
    anyone has any idea that can help me ?
    Bombay, India
    Just a suggestion. Can you not send the frequency after SW1 is hit? Or does that not work as well?
    Greetings Jerson,
    thank you for your reply
    One question:
    When needed to stop the HPWM we just place a zero duty value but internally the module is still active and on standby.
    Is it possible to really shutdown the HPWM module, like for example placing the "CCP1CON=0" in the code's last loop ?
    Bombay, India
    Greetings ruijc
    Setting HPWM value to 0 should be sufficient to keep the output off, but, it should be ok to put it off as you suggested.
