How to blink 8 LEDs at different rates- concurrently?
Results 1 to 15 of 15
    May 2007
    Default How to blink 8 LEDs at different rates- concurrently?
    To do the equivalent of the code below with each LED blinking at a different rate - except that all 8 LEDs must blink concurrently.
    PORTB = 0
    TRISB = 0
    MAIN:
    LOOP1:
      TOGGLE PORTB.0
      PAUSE 500
    GOTO LOOP1
    LOOP2:
      TOGGLE PORTB.1
      PAUSE 220
    GOTO LOOP2
    LOOP3:
      TOGGLE PORTB.2
      PAUSE 380
    GOTO LOOP1
    LOOP4:
      TOGGLE PORTB.3
      PAUSE 750
    GOTO LOOP4
    LOOP5:
      TOGGLE PORTB.4
      PAUSE 170
    GOTO LOOP5
    LOOP6:
      TOGGLE PORTB.5
      PAUSE 400
    GOTO LOOP6
    LOOP7:
      TOGGLE PORTB.6
      PAUSE 620
    GOTO LOOP7
    LOOP8:
      TOGGLE PORTB.7
      PAUSE 130
    GOTO LOOP8
    GOTO MAIN
    You want them all to come on at the same time and drop out at different rates?
    PORTB = %11111111
    PAUSE XXX
    PORTB = %11111110
    PAUSE XXX
    PORTB = %11111100
    LOOP OVER...
    Something like that?
    Have as many LED's as you have pins...
    	LoopALED var BYTE
    	LoopBLED var BYTE
    	LoopCLED var BYTE
    	LoopDLED var BYTE
    	LoopELED var BYTE
    	LoopFLED var BYTE
    	LoopGLED var BYTE
    	LoopHLED var BYTE
    	LoopACON con 50
    	LoopBCON con 22
    	LoopCCon con 38
    	LoopDCon con 75
    	LoopECon con 17
    	LoopFCon con 40
    	LoopGCon con 62
    	LoopHCon con 13
    	TRISB=0
    Loop:
    	If LoopALED=0 then
    		LoopALED=LoopACON
    		Toggle PortB.0
    		LoopALED=LoopALED-1
    	If LoopBLED=0 then
    		LoopBLED=LoopBCON
    		Toggle PortB.1
    		LoopBLED=LoopBLED-1
    	If LoopCLED=0 then
    		LoopCLED=LoopCCON
    		Toggle PortB.2
    		LoopCLED=LoopCLED-1
    	If LoopDLED=0 then
    		LoopDLED=LoopDCON
    		Toggle PortB.3
    		LoopDLED=LoopDLED-1
    	If LoopELED=0 then
    		LoopELED=LoopECON
    		Toggle PortB.4
    		LoopELED=LoopELED-1
    	If LoopFLED=0 then
    		LoopFLED=LoopFCON
    		Toggle PortB.5
    		LoopFLED=LoopFLED-1
    	If LoopGLED=0 then
    		LoopGLED=LoopGCON
    		Toggle PortB.6
    		LoopGLED=LoopGLED-1
    	If LoopHLED=0 then
    		LoopHLED=LoopHCON
    		Toggle PortB.7
    		LoopHLED=LoopHLED-1
    	Pause 10
    	Goto Loop
    Homework Done! Melanie's off down the pub...
    Now repeat the above (excluding definitions) in less than 8 Lines of Code... (yes it can be done)!
    May 2007
    mack, the LEDs need to blink all at the same time, so that will not work.
    Mel, use arrays and a for-next loop - along these lines?
    Loop:
    for x = 0 to 7
      If LoopLED[x] = 0 then
        LoopLED[x] = LoopCON[x]
        Toggle PORTB.x
        LoopLED[x] = LoopLED[x]-1
    next x
    Pause 10
    Goto Loop
    Yes, pretty much, but I don't think PortB.x will work, so...
    	ShadowPortB=0
    Loop:
    	for x = 0 to 7
    			ShadowPortB.0(x)=ShadowPortB.0(x)^1
    		next x
    	PortB=ShadowPortB
    	Pause 10
    	Goto Loop
    Where ShadowPort is a BYTE.
    Just to be different ...
    And because she said "less than 8 Lines of Code" ...
    TRISB = 0
        x = (x + 1) // 8
        PORTB.0(x) = !(LoopLED(x) < LoopCON(x))
        LoopLED(x) = (LoopLED(x) + 1) // (LoopCON(x) << 1)
        if x=7 THEN PAUSE 10
    GOTO Main
