Can´t get DT´s interrupts working
Results 1 to 8 of 8
    Quote Originally Posted by Mugelpower View Post
    now I get those errors:
    Error C: \pbp\pbppic14.lib 1160 : [225]undefined symbol 'INT_ENTRY'
    Error C: \pbp\pbppic14.lib 1162 : [225]undefined symbol 'INT_ENTRY'
    Error : [212] extra tokens on end of line
    I get your errors if I do this:
        INT_Handler TMR1_INT, _ClockCount, PBP, yes
        ;INT_CREATE ; Creates the interrupt processor
        INT_ENABLE TMR1_INT ; Enable Timer 1 Interrupts
    Jan 2008
    Selm, Germany
    Red face got a supersimple DT Timer working
    Hi Guys & Dolls,
    got the DT program running but needed to implement a stupid LCD comment first!
    otherwise the lcd shows only rubbish
    '*  Notes   : To use this example with MicroCode Studio, you    *
    '*          : should:                                           *
    '*          : PIC 16F88 4 MHZ crystal                           *
    '*                   WORKS!                  ´                  *
        CMCON = 7         ' Disable analog comparator
        ANSEL = %00000000     ' set all to digital
    Include "modedefs.bas"
    define OSC 4            ' this example uses a 4MHz clock
            CMCON = 7                ' RA0-RA3 are digital I/O
            TRISA = 0                ' PORT A is output
             TRISB = 3       ' RB0 is Input count RB1 Input reset others output
    Minute   var     byte    ' Define minute variable
    Second   var     byte    ' Define second variable
    Ticks    var     byte    ' Define pieces of seconds variable
    DoUpdate var     byte    ' Define variable to indicate update
    clear             ' clear all RAM (sets all VAR declarations to zero)
    DoUpdate = 1      ' Force first display
    OPTION_REG = %00000101            ' Set TMR0 configuration
    INTCON = $A0                ' Enable TMR0 interrupts
    On Interrupt Goto TickInterrupt
             PAUSE 100
            LCDOUT $FE,1,"Guten"
            pause 2000
             LCDOUT $FE,1,"Tag"
            pause 2000
    ' Main program loop
    MainLoop:
       if DoUpdate then
          LCDOUT $FE,1
           LCDOUT $FE,1,DEC2 Minute, ":",DEC2 Second
           DoUpdate = 0
       Goto MainLoop
    ' Interrupt routine to handle each timer tick
    ' Disable interrupts during interrupt handler
    disable
    TickInterrupt:
       Ticks = Ticks + 1                 ' Count pieces of seconds
       If Ticks < 61 Then ExitInterrupt  ' 61 ticks per second
      ' One second elasped - update time
       Ticks = 0
       Second = Second + 1
       If Second >= 60 Then
          Second = 0
          Minute = Minute + 1
          If Minute >= 60 Then
             Minute = 0
       Endif
       DoUpdate = 1      ' Set update
    ExitInterrupt:
        INTCON.2 = 0    ' Reset timer interrupt flag
        Resume
    this is a far cry from my goal but at least a big jump for me, an unbelievable small step for mankind, maybe a step back.....
