Canīt get DTīs interrupts working
Results 1 to 8 of 8
    Jan 2008
    Selm, Germany
    Unhappy Canīt get DTīs interrupts working
    Hy guys.
    Iīm trying to build a little counter to count pulses of varying speed from nil to 120Hz.
    YEEES it will be a tripmaster speedo someday.
    Tried that with "count" and it works so far, but looses pulses of course and I need every, at least 99,9% of these.
    So I tried to get into DTs interrupts and Iīm falling on my face (hurts of course)
    because I dunno where to start. Tried "Hello World", "Blinky Light", wont do.
    So I thought its because of the missing definitions and tried some....wont do
    all I get after compiling is the error:
    ERROR: Variable wsave3 position request 416 beyond RAM_END 335.
    I got Microcode studio 3.0.0.5, picbasic pro 2.50 C
    heres my code (stolen from DT of course)
    '*  Name    : ElapsedtimerDT1                                   *
    '*  Author  : Darrel Taylor                                     *
    '*  Notice  : Copyright (c) 2010 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 25.04.2010                                        *
    '*  Notes   :  16F628A, 4mhz , donīt care about correct timing  *
    '*  Date    : Jan 10, 2006                                      *
    '*  Notes   : This is a simplistic demo of the Elapsed Timer    *
    define LOADER_USED 1
    define  OSC 4
    ' Define LCD connections
    DEFINE  LCD_DREG        PORTA    ' LCD Data Port
    DEFINE  LCD_DBIT        0        ' Starting Data Bit
    DEFINE  LCD_RSREG       PORTA    ' Register Select Port
    DEFINE  LCD_RSBIT       4        ' Register Select Bit
    DEFINE  LCD_EREG        PORTA    ' Enable Port
    DEFINE  LCD_EBIT        5        ' Enable Bit
    DEFINE  LCD_BITS        4        ' Data Bus Size
    DEFINE  LCD_LINES        2        ' Number of Lines on LCD
    ADCON1 = 7                        ' Set portA outputs to Digital / No ADC
    'CMCON  = 7
    LCDOUT $FE,1                    ' Initialize LCD
    PAUSE  200
    include "DT_INTS-14.bas"
    INCLUDE "ReEnterPBP.bas"
    INCLUDE "Elapsed_INT.bas"
            INT_Handler   TMR1_INT,  _ClockCount,   PBP,  yes
        INT_ENABLE  TMR1_INT  ; Enable Timer 1 Interrupts
    Gosub ResetTime           ' Reset Time to  0d-00:00:00.00
    Gosub StartTimer          ' Start the Elapsed Timer
        if SecondsChanged = 1 then
           SecondsChanged = 0
           LCDout $FE,$C0, dec Days,"d-",dec2 Hours,":",dec2 Minutes,":",dec2 Seconds
    GOTO Main
    maybe its about compiler version or something.
    any suggestions beyond cry me a river?
    regards Mugelpower
    Hi, MugelPower
    the truth is here :
    '*  Name    : DT_INTS-14.bas                                               *
    '*  Version : 1.00 BETA                                                    *
    '*  Date    : OCT 13, 2009                                                 *
    '* REV 1.00  Completely re-written, with optimization and F1 chips in mind *
    '* REV 0.93  Fixed CMIF and EEIF problem with older PIC's                  *
    '*           that have the Flags in PIR1 instead of PIR2                   *
    '* Rev 0.92  solves a "Missed Interrupt" and                               *
    '*           banking switching problem                                     *
    DEFINE  DT_INTS_VERSION  100
    DEFINE  INTHAND  INT_ENTRY
    wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    ;wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
                                             ' if using $70, comment out wsave1-3
    ' --- IF any of these three lines cause an error ?? ----------------------------
    ' -- It depends on which Chip you are using, as to which variables are needed --
    wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    so, just comment this line out in your DT_ints.bas file ...
    End of trouble ...
    Jan 2008
    Selm, Germany
    Unhappy now the errors changed
    I changed to 16F88 because of the 16bit timer i need later (or now)
    now I get those errors:
    Error C: \pbp\pbppic14.lib 1160 : [225]undefined symbol 'INT_ENTRY'
    Error C: \pbp\pbppic14.lib 1162 : [225]undefined symbol 'INT_ENTRY'
    Error : [212] extra tokens on end of line
    Jan 2008
    Selm, Germany
    Unhappy DT_INTS-14.bas version 1.0
    Man where do I get the newest version:
    regards
    Mugelpower
    Quote Originally Posted by Mugelpower View Post
    Man where do I get the newest version: DT_INTS-14.bas version 1.0
    Here at bottom of page: http://darreltaylor.com/DT_INTS-14/intro2.html
    I get your errors if I do this:
        ;INT_CREATE ; Creates the interrupt processor
    Jan 2008
    Selm, Germany
    Red face got a supersimple DT Timer working
    Hi Guys & Dolls,
    got the DT program running but needed to implement a stupid LCD comment first!
    otherwise the lcd shows only rubbish
    '*  Notes   : To use this example with MicroCode Studio, you    *
    '*          : should:                                           *
    '*          : PIC 16F88 4 MHZ crystal                           *
    '*                   WORKS!                  ī                  *
        CMCON = 7         ' Disable analog comparator
        ANSEL = %00000000     ' set all to digital
    Include "modedefs.bas"
    define OSC 4            ' this example uses a 4MHz clock
            CMCON = 7                ' RA0-RA3 are digital I/O
            TRISA = 0                ' PORT A is output
             TRISB = 3       ' RB0 is Input count RB1 Input reset others output
    Minute   var     byte    ' Define minute variable
    Second   var     byte    ' Define second variable
    Ticks    var     byte    ' Define pieces of seconds variable
    DoUpdate var     byte    ' Define variable to indicate update
    clear             ' clear all RAM (sets all VAR declarations to zero)
    DoUpdate = 1      ' Force first display
    OPTION_REG = %00000101            ' Set TMR0 configuration
    INTCON = $A0                ' Enable TMR0 interrupts
    On Interrupt Goto TickInterrupt
             PAUSE 100
            LCDOUT $FE,1,"Guten"
            pause 2000
             LCDOUT $FE,1,"Tag"
            pause 2000
    ' Main program loop
    MainLoop:
       if DoUpdate then
          LCDOUT $FE,1
           LCDOUT $FE,1,DEC2 Minute, ":",DEC2 Second
           DoUpdate = 0
       Goto MainLoop
    ' Interrupt routine to handle each timer tick
    ' Disable interrupts during interrupt handler
    disable
    TickInterrupt:
       Ticks = Ticks + 1                 ' Count pieces of seconds
       If Ticks < 61 Then ExitInterrupt  ' 61 ticks per second
      ' One second elasped - update time
       Ticks = 0
       Second = Second + 1
       If Second >= 60 Then
          Second = 0
          Minute = Minute + 1
          If Minute >= 60 Then
             Minute = 0
       Endif
       DoUpdate = 1      ' Set update
    ExitInterrupt:
        INTCON.2 = 0    ' Reset timer interrupt flag
        Resume
    this is a far cry from my goal but at least a big jump for me, an unbelievable small step for mankind, maybe a step back.....
    Hey Mulgepower, glad to hear it.
    Remember to put your code in brackets like this but without the extra spaces...
    [ code]
    code goes here
    [ /code]
    so it is easier to read?
    Walter
