Math for dunce...
Results 1 to 6 of 6
    Dec 2008
    Ploiesti, ROMANIA
    Default Math for dunce...
    I have three value : 25 ; 25.23 ; 26.02
    I must do this : If 26.02 - (25/100) > 25.23 then do something...
    Since the numbers are not integers, my results are wrongs. Please, a little help. Thanks in advance.
    Just multiply everything by 100.
    Then it becomes ...
    If (2602 - 25) > 2523 then do something...
    Dec 2008
    Ploiesti, ROMANIA
    Thank You, Mr.Darrel !
    I have already do this, but...Maybe it's another mistake..So, I put the code.
    I read the temperature :
     OWOut DQ, 1, [$CC, $44]
     OWOut DQ, 1, [$CC, $BE]
     OWIn DQ, 2, [temperature.byte0, temperature.byte1]
                    SignBit = 0
                    if  temperature.15 then
                        temperature  = ~ temperature + 1
                        SignBit = 1
    Dummy = 625 * Temperature
    TempC = DIV32 10
    TempC = (Temperature & $7FF) >> 4
    Float = ((Temperature.Lowbyte & $0F ) * 25 )>>2
    Temperature=TempC*100 + Float
     	If SignBit then
      		V= 10000 - Temperature   	' 25'C=12500  0'C=10000  -10'C=9000
      		SignBit = 0
      		V= 10000 + Temperature
     	EndIf
    	If V >= 10000 then             	' Above 0 C.
      		Temperature=V-10000
      		Temperature=10000-V      	' Below 0 C.
     	EndIf
     GoSub SelectSign                    	' +/blank/- Sign
    SelectSign:
     If v = 10000 then                      	' Temperature = 0 C.
      	Sign=" " 				      ' No sign
         Else
      		If v < 10000 then             ' <> 0
       			Sign="-"			' Temperature below 0 C.
      		    Else
       			Sign="+"			' Temperature above 0 C.
      		EndIf
     EndIf
    At the beginning I set the hysterezis for thermostat :
     If Mode=1 then                        	' Set Hysteresis
                    LcdReg  =  %10000000 + 12 ' cursor  X
                    call    PrintCtrlLcd
                    LcdReg  =  %01000010      ' cursor  Y
                    call    PrintCtrlLcd
                    Char = 21
                    call    PrintChar
                    Char = 19
                    call    PrintChar
                    Char = 20
                    call    PrintChar
                    Char = 15
                    call    PrintChar
      Gosub DTemp                           	' Display Hysteresis
      If (PORTB.1=0) Or (PORTB.2=0) then    	' Up or down button pushed
       If PORTB.2=0 then                    	' Down button
                if hyst > 5 then hyst=hyst-5
                If Hyst < 5  then Hyst=5
                Gosub Debounce
       EndIf
       If PORTB.1=0 then                    	' Up button
                hyst=hyst+5
                If Hyst > 50 then Hyst=50
                Gosub Debounce
       EndIf
      EndIf
     EndIf
    DTemp :
             LcdReg  =  %10100000 + 14      	' cursor  X
             call    PrintCtrlLcd
             LcdReg  =  %01000100           	' cursor  Y
             call    PrintCtrlLcd
             Char = (hyst dig 2) + 2
             call    PrintChar
             Char = 14
             call    PrintChar
             Char = (hyst dig 1) + 2
             call    PrintChar
             Char = (hyst DIG 0) + 2
             Call    PrintChar
    and I try to do this :
    check:
     if temperature > (tref + hyst) then
        tref=temperature
     		duratavar=(temperature-tref)/hyst
     		duratavar=duratavar*durata
     	if tipsun=2 then
     		sound PORTB.6, [varsnd, duratavar]
     		sound PORTB.6, [varsnd, 20]
     	endIf
     if temperature < (tref - hyst) then
        tref=temperature
     		duratavar=(tref-temperature)/hyst
     	if tipsun=2 then
     		sound PORTB.6, [varsnd2, duratavar]
     	      sound portb.6, [varsnd2, 10]
    Everything works great, but this "if temperature > (tref + hyst) then" return wrong results.
    Note : hyst, temperature, tref are var Word.
    Hysterezis must be max 0.50 'C, with step of 0.05 'C. On display works fine, but inside the code I think I made mistake...Thank You !
    Not really sure what all is going on in your program fratello.
    So let me just show what I would do.
    First ... It takes 750mS from the time you start a conversion till you can read the results.
    You can just put a pause after the Convert command [$CC, $44], to wait till it's done.
    Or you can Poll the DS18B20's busy bit.
    Once you have the reading from the DS18B20, it can be converted like this...
        Sign = TempC.15
        TempC = ABS(TempC)
        TempC = ((TempC >> 4)*100) + ((TempC & $F)*100 >> 4)
        IF Sign THEN TempC = -TempC
    That gives you a Signed Word with 2 decimal places.
    25.00 °C would have the value 2500.
    -10.00 °C would be -1000.
    It will work with the full temperature range of the sensor -55°C to +125°C.
    You can display it on an LCD with this ...
    DisplayTemp:
        IF TempC.15 THEN LCDOUT "-"
        LCDOUT DEC ABS TempC/100,".", DEC2 ABS TempC,13,10
    To compare the Temp with your hysteresis range, you just subtract the values.
    If the value being subtracted is larger than the other one, the result will be negative.
    So, just testing for the sign bit tells you if it's above or below the setpoints.
    Compare:
        Diff = (tref + Hyst) - TempC
        Over = Diff.15
        Diff = TempC - (tref - Hyst)
        Under = Diff.15
    Over and Under are BIT vars, so you can test them later in the program to activate alarms or whatever.
    Keep in mind that with 12-bit resolution, each step of the DS18B20's reading is 0.0625°C.
    So incrementing the hyst. 0.05°C won't always give the expected Hyst. range.
    It'll be close, but not perfect.
    Test program attached.
    Dec 2008
    Ploiesti, ROMANIA
    As always, Mr.Darrel it's one fine Gentleman. Thank You ! I will test and I will post the results !
    Dec 2008
    Ploiesti, ROMANIA
    It's OK, of course !
    BTW: Just for fun ; I redefine in my source "hyst" as byte (previous = word) and the results are similares !
