Minimalist Numeric Display ideas
Results 1 to 12 of 12
    Oct 2009
    Utah, USA
    Default Minimalist Numeric Display ideas
    hey Group,
    I am building an hour meter for my Honda Generator...
    (I know, I know... I can buy one for around $35...
    but then where would the FUN be in that? )
    I am trying to think of a simple method of displaying the current hour meter value.
    Some possibilities...
    • Use an LED (possibly bi-color) to count (blink) for each digit. Possibly in morse code.
    • An inexpensive 3 or 4 digit LCD (I don't have a source for this, any help is appreciated)
    Any ideas from the group on some sort of "minimalist" display would be appreciated, or a source for a small 4 digit LCD. I am trying to keep this small and simple.
    Dwight
    Is this too big? I have not used it, but the price seems good, and it would be durable.
    http://www.sparkfun.com/commerce/pro...oducts_id=9480
    Or use a piezo speaker, and buzz out each digit.
    Then if you want a little more difficult, have it talk the numbers out with Roman Black sound. See: http://www.picbasic.co.uk/forum/show...0131#post90131
    Oct 2009
    Utah, USA
    Default can't see the forest for the trees!!
    duh... don't know why I did not think of a 7 seg LED display!!
    I can even just use one digit and briefly display each digit of the total.
    For some reason I was stuck on LCD (and the associated difficulty of finding and interfacing to the pic with a non 44780 hitachi controller.) I know it would be easy to interface a 2x16 LCD or what ever but that is overkill and drives up the cost.
    THANKS! for opening up my eyes. Mabie it was actually "Tunnel Vision" that I had, or a "one track mind".
    Still open to other ideas and suggestions, but now I can start on the code.
    this place is the greatest!!
    Dwight
    USA - Arizona
    Default Take a look at KTM-S1201
    Take a look at KTM-S1201.
    SPI, 12-digit LCD.
    Wink Why do it simple ???
    Hi, Heckcler
    Sometimes ago I've built a little onboard computer for my lawntractor ( RPM,temps,voltage,hours, ... + servicing alerts ) ... everything displayed with a little 2x8 LCD ... a GDM0802B from Xiamen Ocular
    for just an hour meter, you could easily build that around a 16F628 ... or 16F88 if you need voltages.
    Not bashing ( who, me ???) Honda sells nice hour meters ... ref: 08174-ZL8-000HE
    ah, I forgot ... I'ts a computer for a Honda tractor !!!
    Nov 2007
    West Covina, CA
    Default How about these?
    Currently playing around with the 16F913 and a LCD-S401M14TF (Mouser $1.26). The 16F913 has the LCD driver and the LCD is tiny and cheap!
    I have them on a 1.61" x 1.61" PCB but plan on making it smaller yet.
    Louie
    Default My 2 cents . . .
    Make it as big or small as you like, the PIC has the power . . . Another way is to use 8 SMD LEDs and display in binary 0 to 255 hours. It can get very small that way.
    USA - Arizona
    Quote Originally Posted by languer View Post
    SPI, 12-digit LCD.
    One thing I forget to mentioned; the display is priced at $0.95. Not bad for SPI (3-wire, 5 actually) interface, 12 digit (7-seg) display.
    Oct 2009
    Utah, USA
    Thanks to "The Group" for all the various ideas and comments... I have plenty to consider and play with.
    Question to Langure...
    Have you used these displays? Are they allready set up for serial communication? What baud?
    They are amazingly inexpensive... great find!
    Dwight
    Dwight
    Default Cheap character display
    If you want a character lcd display for cheap, here is a single line 24 character display for $1.49. It's not very small though.
    http://www.goldmine-elec-products.co...?number=G15318
    USA - Arizona
    Dwight
    I did, different programming environment -> http://tech.groups.yahoo.com/group/p...e/message/2016
    May 2010
    Chile
    Just to add to the "idea pool" of minimal digit displays.
    Usually i'm too lazy to wire a seven segment display to a protoboard design just to debug a value in a variable.
    For that reason, i've made a small subroutine that blinks a led according to the value of a variable, For fast and ease of translation the variable is divided in its digits. Easy and fast to read.
    Here is a code sample:
    '["asynchronous serial protocol for human eye..."]
    '[put your port configs and more here]
    '---- Define Variables part
    x var byte
    Y var byte
    n var byte
    '---- Main program
    x = 123 'any value
    gosub blinkled 'blink led according to X
    '--- Subroutine part
    blinkled:  'blink led on GPIO.1 according to X value
        if x > 99 then '1st digit
            y = x dig 2
            gosub blinkloop 'blink the digit
            gpio.1 = 1 'one final large blink to separate digits
            gpio.1 = 0
            pause 400
        if x > 9 then  '2nd digit
            y = x dig 1
            gpio.1 = 0
            pause 400
        y = x dig 0    '3rd digit
    blinkloop: 'blink subroutine
        for n = 1 to y
            gpio.1 = 1
            gpio.1 = 0
            pause 400
        next n
    Actually i've made a wrist clock out of it with just 2 leds as a display
    Enjoy
