how can I caculate with numbers bigger than a word using 16F88 ?
Results 1 to 10 of 10
    Jan 2008
    Selm, Germany
    Cool how can I caculate with numbers bigger than a word using 16F88 ?
    Hi Guys & Dolls,
    to make my tripmaster accurate I need to crunch bigger numbers.
    my code works like this:
    '---[INT - interrupt handler]---------------------------------------------------
    ToggleLED1:
    cnt = cnt +1
    cntb = cnt * 20
    meter = cntb / f0
    If meter = x Then
    meter = 0
    km = km + 1
    cnt = 0
    Endif
    @ INT_RETURN
    but to get more accuracy I need cntb = cnt * 1000 with a maximum of cnt around 4000.
    makes 4000000 maximum for cntb .
    How could I do that fast enough in my interrupt routine?
    Mugelpower
    The easy way would be using an 18Fxxx with PBP 2.50 or greater. That way you have LONGs.
    Other wise you are stuck with dividing down and messing with HIGH BYTE/LOW BYTE stuff. Just not worth is these days.
    Sep 2005
    Campbell, CA
    I'm trying to rid the world of 16F chips, but try this
    http://www.picbasic.co.uk/forum/show...ght=n-bit_math
    Charles Linquist
    Bombay, India
    What is x20?
    what is f0?
    what is x?
    A little more detail and it is possible that a different solution exists.
    The last time I did something similar, I had a pulses per mile count. After that the mile count would increase by 1. To handle numbers as big as 99999999 you can do it in code like I did
    Pseudo code begins
    miles[4]    var    byte         ' lsb to msb
            on input pulse,  pulses=pulses+1
            if pulses >= Pulsespermile
                  pulses = 0                               ' start counting again till we reach pulses per mile
                  miles[0] = miles[0]+1
                  if miles[0] > 99 then
                       miles[0]  =0
                       miles[1] = miles[1]+1
                       if miles[1] > 99 then
                            miles[1] = 0
                            miles[2] = miles[2]+1
                            if miles[2] > 99 then
                                  miles[2] = 0
                                  miles[3] = miles[3]+1
                                  if miles[3] > 99 then
                                       miles[3] = 0   ' roll over to all zero
    Now, displaying this is easy.
          Num = miles[0] dig 1                ' first digit to display
          digitpos = 0
          gosub displaynum                   ' show the number
          Num = miles[0] dig 0                ' 2nd digit to display
          digitpos = 1
          Num = miles[1] dig 1                ' 3rd digit to display
          digitpos = 2
          Num = miles[1] dig 0                ' 4th digit to display
          digitpos = 3
    and so on
    May 2010
    Royston Vasey, UK
    Quote Originally Posted by Charles Linquis View Post
    I'm trying to rid the world of 16F chips...
    I'm with you, Charles, but is there a PIC18 that is nearly the same price as a PIC16F88? I'm doing a low cost consumer product right now where 40 cents makes a big difference. Until that time, that evil PIC16F architecture lives on.
    These are the good old days.
    Sep 2005
    Campbell, CA
    In some cases,(like high-volume applications), the 16F series makes sense. But too often I see people that work hours (or tens of hours) longer to get something to work because they started out with an inadequate chip on a one-off project.
    Charles Linquist
    May 2007
    Quote Originally Posted by NullDevice View Post
    According to here PIC16F88 the lowest cost device is $2.20 - if you go here PIC18 Product Family and do a sort on ascending price, you will find about 45 PIC18's that cost less than a PIC16F88. That said, I use several competitive 32-bit devices that are about half that price.
    Not sure, but maybe you can just change 1-line.
    ToggleLED1:
       cnt = cnt +1
       cntb = cnt * 20 ; could be * 1000
       meter = DIV32 f0
       If meter = x Then
         meter = 0
         km = km + 1
         cnt = 0
       Endif
    @ INT_RETURN
    Depends on what f0 and x are.
