16f1936
Results 1 to 5 of 5
Thread: 16f1936
    May 2009
    Default 16f1936
    I am using the new extended 16F1936 and am having a problem accessing the EEPROM from PICBASIC pro. I Have PBP 2.60. When I try to use the WRITE command I get an error 113 stating that The Symbol (WRITE) is not previously defined. The device has 256 bytes of eeprom.
    Is this device not supported by the WRITE command?
    Has anyone had any experience with this device?
    There is a wee bug in this version of PBP, this should help.
    http://www.picbasic.co.uk/forum/showthread.php?t=12527
    Hi, Graham
    could you provide a piece of program ( variables declaration + guilty WRITE commands ) ???
    Dave pointed it out, but here it is if you have trouble finding it: http://melabs.com/support/pbpissues.htm
    Add this at the top of your code:
    DEFINE WRITE_USED 1
    May 2009
    Thank you to all. The Define has fixed the problem.
    Graham
