EasyPic 5 board and MCSP
Results 1 to 8 of 8
    malc-c's Avatar
    malc-c Guest
    To be honest I don't think it will work with MCSP, the manual ( http://www.mikroe.com/pdf/easypic5/mikroicd_manual.pdf ) provides details of how to configure and use the Mikro ICD software, which might be your only option
    Post
    Hi, Alexander
    at this time , I have my Easypic5 connected to MCSP in debug mode, with a 16F877A ... and it works fine.
    so, it's possible.
    1) I use a " true " RS232 serial cable from a serial port of the PC - no USB convertor. ( choice is only COM 1,2 & 4 ... )
    I have an USB > serial on com 4 ( PSU ) and it works too, if connected to EP5 ...
    2) the EP5 RS232 switches ( SW7 & SW8 ) must be selected to allow the choosen Pic to use it's own USART.
    except that ... nothing special.
    Apr 2010
    Moscow
    Default Mr
    Hi, Alexander
    so, it's possible.
    Merci Alain
    What loader are you using? Is it possible to use MC Loader?
    I have 16F887 on board. Its not on the list. What can I put instead?
    Alexander
