EasyPic 5 board and MCSP
Results 1 to 8 of 8
    Apr 2010
    Moscow
    Default EasyPic 5 board and MCSP
    I've got Easy Pic 5 board- very nice but can't get it work with MCSP. Did some one manage to do it? I find a ref in your forum www.picbasic.co.uk/forum/content.php?r=84 but no content there. I'm using USB- RS232 adapter.
    malc-c's Avatar
    malc-c Guest
    When you say you are using USB to RS232, do you mean you are using a com port on the PC to connect to the programmer's USB port via an adapter - If so then I think you are going to have trouble.
    A bit more info on how / what you are trying to do would be useful.
    Apr 2010
    Moscow
    Default Reg RS232
    Quote Originally Posted by malc-c View Post
    Thanks, I have notebook with USB ports only therefore I'm using adapter to connect to RS232 on Easy Pic 5 board. I'm trying to use ICD capabilities of MCSP. A correct loader I have.
    Alexander
    malc-c's Avatar
    malc-c Guest
    To be honest I don't think it will work with MCSP, the manual ( http://www.mikroe.com/pdf/easypic5/mikroicd_manual.pdf ) provides details of how to configure and use the Mikro ICD software, which might be your only option
    Post
    Hi, Alexander
    at this time , I have my Easypic5 connected to MCSP in debug mode, with a 16F877A ... and it works fine.
    so, it's possible.
    1) I use a " true " RS232 serial cable from a serial port of the PC - no USB convertor. ( choice is only COM 1,2 & 4 ... )
    I have an USB > serial on com 4 ( PSU ) and it works too, if connected to EP5 ...
    2) the EP5 RS232 switches ( SW7 & SW8 ) must be selected to allow the choosen Pic to use it's own USART.
    except that ... nothing special.
    Apr 2010
    Moscow
    Default Mr
    Hi, Alexander
    so, it's possible.
    Merci Alain
    What loader are you using? Is it possible to use MC Loader?
    I have 16F887 on board. Its not on the list. What can I put instead?
    Alexander
    Default MCLoader compatible chips
    Any supported chip should do, as long as your board's serial port can match up with the chips, it should work. Here are the hex files available for MCLoader, attachment at the bottom of this page:
    http://www.picbasic.co.uk/forum/cont...Bootloader-Hex
    FranMah's Avatar
    FranMah Guest
    Default Re: EasyPic 5 board and MCSP
    Hey
    I have easy pic 5 board. Its awesome except 1 thing that can't get it work with MCSP.
    Please tel me what should i do.???
