To calculate a constant for a different crystal frequency
Results 1 to 6 of 6
    May 2009
    Montreal, QC, Canada
    Default To calculate a constant for a different crystal frequency
    I am trying to get some information indicated in file "Elapsed_INT" from DT_INT
    In the file it reffers to a link which does not exist possibly since this forum changed yesterday.
    ' To calculate a constant for a different crystal frequency - see this web page
    ' http://www.picbasic.co.uk/forum/showthread.php?t=2031
    Is there any way to get to it?
    Mike
    That thread got lost about a year or so ago.
    Fortunately, there's something much better from mister-e.
    Use the Timer Helper app in this ...
    PicMultiCalc V_1.3.1
    http://www.picbasic.co.uk/forum/atta...achmentid=2957
    May 2009
    Got it thanks,
    I am trying to understand how to use it to calculate what I need, nonetheless it is hard enough for me to even know what I need but is there any tutorial/examples available?
    Mike
    May 2009
    I think I will be ok with this after all.
    The only thing I don't have a clue what it is for and/or how to apply is the value called "Reload(instr. Cycle)" but it doesn't seam to affect anything.
    Mike
    The "Reload(instr. Cycle)" value is important for Long-Term accuracy.
    It represents the number of Clock Cycles (instructions) that it takes to Reload the timer.
    In the case of Elapsed_INT ... there are 7 cycles between the point where the timer is stopped until it's been reloaded and turned back on again.
    ; -----------------  ADD TimerConst to TMR1H:TMR1L
    ADD2_TIMER   macro
        CHK?RP  T1CON
        BCF     T1CON,TMR1ON           ; Turn off timer
        MOVLW   LOW(TimerConst)        ;1  1
        ADDWF   TMR1L,F                ;2  1    ; reload timer with correct value
        BTFSC   STATUS,C               ;3  1/2
        INCF    TMR1H,F                ;4  1
        MOVLW   HIGH(TimerConst)       ;5  1
        ADDWF   TMR1H,F                ;6  1
    ; -----------------  ADD TimerConst to TMR1H:TMR1L and restart TIMER1 ----------
    RELOAD_TIMER  macro
        ADD2_TIMER
        BSF     T1CON,TMR1ON           ;7  1    ; Turn TIMER1 back on
    7 is also the default number in mister-e's program, but different reload routines may take longer, or shorter times.
    hth,
    May 2009
    That's great information.
    Thank you
    Mike
