To calculate a constant for a different crystal frequency
Results 1 to 6 of 6
    May 2009
    Montreal, QC, Canada
    I think I will be ok with this after all.
    The only thing I don't have a clue what it is for and/or how to apply is the value called "Reload(instr. Cycle)" but it doesn't seam to affect anything.
    Mike
    The "Reload(instr. Cycle)" value is important for Long-Term accuracy.
    It represents the number of Clock Cycles (instructions) that it takes to Reload the timer.
    In the case of Elapsed_INT ... there are 7 cycles between the point where the timer is stopped until it's been reloaded and turned back on again.
    ; -----------------  ADD TimerConst to TMR1H:TMR1L
    ADD2_TIMER   macro
        CHK?RP  T1CON
        BCF     T1CON,TMR1ON           ; Turn off timer
        MOVLW   LOW(TimerConst)        ;1  1
        ADDWF   TMR1L,F                ;2  1    ; reload timer with correct value
        BTFSC   STATUS,C               ;3  1/2
        INCF    TMR1H,F                ;4  1
        MOVLW   HIGH(TimerConst)       ;5  1
        ADDWF   TMR1H,F                ;6  1
    ; -----------------  ADD TimerConst to TMR1H:TMR1L and restart TIMER1 ----------
    RELOAD_TIMER  macro
        ADD2_TIMER
        BSF     T1CON,TMR1ON           ;7  1    ; Turn TIMER1 back on
    7 is also the default number in mister-e's program, but different reload routines may take longer, or shorter times.
    hth,
    May 2009
    That's great information.
    Thank you
    Mike
