tried this circuit which didn't work too...
Hello, ultramegaok
You will not be able to send any thing out to the phone line through a bridge rectifier!
The only thing the bridge rectifier is good for, on a phone line, is drawing power FROM the phone line to power some circuitry. You need to use a 600:600 isolation transformer. Go to www.microchip.com and lookup application note AN854. There in Figure 1 is an example of what it takes (their engineer's opinion) to communicate over the phone lines using a PIC and a few discrete components.
Pretty much any circuit today uses the transformer to isolate the product from the phone line. There are several alarm dialers on the market that use opto-isolators and P-mos relays to connect to the phone line. Did you look at the site that I listed on my first reply?
BobK
You'll be wanting to run your pic at 20MHz to stand a chance of your phone system
recognizing the DTMF tones produced by PicBasic/Pro.
Don't forget to DEFINE OSC 20
The tones produced by the pic aren't a very pure sine wave.
An external DTMF generator chip would be best,
but I have used a 16F84 to dial numbers and navigate DTMF phone menu systems.
One project was an automated thing to retrieve my bank balance over the phone on payday.
Hi ultramegaok
I have done a lot of development accessing the PSTN using Pics and PBP Pro
First of all, the DTMF tones out of a PIC are dreadful as produced on the pin - you need to clean them up with an active low pass filter. This will remove all t he nasty higher order stuff that clogs it and will produce a pretty good DTMF waveform. Using a single opamp 2nd order filter, I was able to shape and send tones without problems, and have them accepted at destination. And yes, clock at 20Mhz minimum to make the waveforms acceptable
Eish! (as we say in South Africa before the World Cup). You need an audio transformer and what is called an "active Gyrator" with a single transistor to match to a PSTN line. Will gladly send design tips
You want to receive DTMF with a PIC? Good luck. It's vastly more complicated, so rather use an industry standard IC like the MT8870 decoder IC. The Microchip website has an application note that decodes DTMF, but it looks like complicated software
Will gladly send u the details on the low pass filter if that interests you.
regards
Angus Anderson
KwaZulu Natal, South Africa
Thanks for the information Angus, could you share the low pass filter circuit that you use before...my project is only to send DTMF (just Dialing)
my email is [email protected].
Greeting from Mexico!!!!
I think my futbol team is going to be in the inaugural game against your team in the wolrd cup
please if you got the solution please tell me too i am also stuck.. i also have to generate DTMF dail tone to call through phone line using pic.. i am using pic 16f877a with 20mhz crystal.. in my programmer i have dtmfout instruction.. i can write dtmfout porta.0, [3] and it will generate dtmf for numbe 3 at porta.0 and it is generating tones but those tones are not working properly.. with ptcl and even if i try to decode those tones using mt8870 the ic is not decoding the tones i don't know about how to filter those please mail me too about how to filter or how to make it work
my email is
[email protected]
Thanks BobK
I have read the website from your first reply which helps me a lot to undertands how telephones work, I was trying to avoid the transformer because I don't have one on hand rigth now, but I think I need to go to radioshack and get one. That seams the most safest way to connect the pic...... I let you now my progress...Checking AN854.
