division problem 500000 / 133
Results 1 to 6 of 6
    Sep 2006
    Default division problem 500000 / 133
    Hello,
    I need to divide 500000 by my input
    so 500000 / input Ex: 500000/145= 3448
    Obviously this is a 20 bit number.
    tried reducing to 50000, but I get stuck with a decimal, used :
    input1 = 50000 / 145 '=344
    output1= input1 >> 2 '=86
    1) How do I combine these two numbers to create one?
    2) maybe there is another and better way to do it ?
    K
    Sep 2006
    Default Re: division problem 500000 / 133
    Thought I had it,
    but there is something fishy about the shifting i believe..
    input1 = 50000 / 142
    input1= input1 * 10
    output1 = output1 /10
    input1 = input1 +output1
    K
    If you're running on a 18F series then you could enable support for LONGS in the compiler and simply be done with it. It will increase the code size quite a bit though so I understand if you're trying to avoid it.
    Have you looked at the DIV32 operator? I'm not 100% sure it'll work with a variable but I think it will, try it out:
    Dummy  VAR WORD
    Result VAR WORD
    Divider VAR WORD
    ' Be aware that Divider must be at least 8 or Result will
    ' overflow and show the wrong result.
    Divider = 145
    Dummy = 500*1000            ' Produce intermediate result of 500000
    Result = DIV32 Divider      ' Divide the intermediate result
    Sep 2006
    I am using the 16F88 chip..
    tried your code but shows 65535 on LCD
    K
    Here is a snipit form a program I use and it works great:
    CALCF_C: 'CALCULATE DEG.F and DEG.C for LM 95231 TEMPERATURE SENSOR READING
    CALCF:
    SCRATCH = TEMPREAD * 1000
    TEMPF = DIV32 17777
    TEMPF = TEMPF * 10
    TEMPF = TEMPF + OFFSET
    CALCC:
    TEMPC = DIV32 32
    Just make sure you don't have any interrupts going on when using DIV32.
    I also think your problem may be that you are using a variable after the DIV32 keyword. Try entering the constant value and see if that doesn't work.
    EN82fn
    Sep 2006
    Result = DIV32 133
    lcdout $FE,2, "Duty:", dec Result
    ... still getting 65535 as output
    Thats all I have in the program, no interrupt nothing else !
    then I initialized my parameters this way:
    a var word
    b var word
    a= 500
    b = 1000
    Dummy VAR word
    Result VAR WORD
    Divider con 145
    Dummy = a * b ' Produce intermediate result of 500000
    Result = DIV32 133
    and its now working.. Dummy doesnt like numbers
  1. // Division Operator
    By Dick Ivers in forum mel PIC BASIC Pro
    Last Post: - 9th September 2011, 15:27
  2. What is wrong with this division?
    Last Post: - 5th March 2010, 18:34
  3. Division by 0
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 4th August 2007, 02:11
  4. Division with some decimal
    By Darklakebridge7 in forum mel PIC BASIC Pro
    Last Post: - 10th May 2007, 07:41
  5. division
    By eoasap in forum mel PIC BASIC Pro
    Last Post: - 28th March 2006, 17:26
