Timing on the 12F675
Results 1 to 8 of 8
    Apr 2010
    Default Timing on the 12F675
    I am using PicBasic Pro with the 12F675. I am using the internal 4MHz oscillator and seem to be having some issues.
    I will need to create 30KHz, 33KHz, 36KHz, 38KHz, 40KHz and 56KHz. 38KHz is the most important and the one that I am working with first. I would like to make a 13uS on and 13uS off square wave.
    If I run just a tight loop turning the output on and off the output is about 4.4uS on and 4.4uS off. Does this sound correct?
    I tried to use pauseus 13 thinking that I would get a 13uS pause but it created about a 25uS pause. pauseus 1 still causes a 25uS pause. Is there that much overhead in turning the pin high and low.
    Here is what I am trying.
    freq38K:
    HIGH IrLed
    PAUSEUS 13
    LOW IrLed
    PAUSEUS 13
    GOTO freq38k
    You might try
    GPIO = %xxxxxxxx
    Make the x's 0 or 1. 1 being high.
    Perth, Australia
    If the frequency needs to be accurate you would be much better off using a timer interrupt.
    as the Holy Manual states ...
    min PAUSEUS @ 4 Mhz is ... 19µs ...
    soooo .... toobad !
    Now, for this " universal IR Tx " ...the use of a Xtal looks compulsory !
    PS: an assembler stubb would be useful here ...
    ; Code generated by PDEL  ver 1.0  on 23/04/2010 at 09:01:45
    ; Description: Waits 13 cycles
    PDelay  movlw     .2        ; 1 set number of repetitions
            movwf     PDel0     ; 1 |
    PLoop0  clrwdt              ; 1 clear watchdog
            decfsz    PDel0, 1  ; 1 + (1) is the time over?
            goto      PLoop0    ; 2 no, loop
            return              ; 2+2 Done
    Code requirements
    - Declaration of PDel0 (register)
    - 1 stack level
    Example of use
    call PDelay      ; Delay 13 cycles (including call+return)
    Jan 2006
    Istanbul
    http://www.rentron.com/Infrared_Communication.htm
    PROCESSOR 12c508
       #include "p12c508.inc"
       __CONFIG  _MCLRE_OFF & _CP_OFF & _WDT_OFF & _IntRC_OSC
       #DEFINE PORT B'11111101'
    	MOVF OSCCAL
    	MOVLW PORT
    	TRIS GPIO
       BEGIN
    	BCF GPIO, 1     ;1uS
    	NOP	        ;2uS each nop is 1uS long
    	NOP		;3uS
    	NOP		;4uS
    	NOP		;5uS
    	NOP		;6uS
    	NOP		;7uS
    	NOP		;8uS
    	NOP		;9uS
    	NOP		;10uS
    	NOP		;11uS
    	NOP		;12uS
    	NOP		;13uS
    	NOP		;14uS
    	NOP		;15uS
    	NOP		;16uS
    	NOP		;17uS
    	NOP		;18uS
    	NOP	        ;19uS
    	BSF GPIO, 1 	;1uS Begin HIGH duty cycle
    	NOP		;2uS
    	NOP		;3uS
    	NOP		;4uS
    	NOP		;5uS
    	GOTO BEGIN      ;2uS (26uS total for 38KHz)
    Something like this is easier with PBP.
    This is in an include file;
      ' IR carrier generator routines. Freq.inc.
      Cycles VAR BYTE    ' Number of carrier cycles
      GOTO OverFreq  ' jump over pulse routines
    ' Generate "Cycles" number of 40kHz pulses
    _Pulse40
       bcf IRTX,PIN     ; 1uS, LED=on
       goto $+1         ; + 2uS = 3uS
       goto $+1         ; + 2uS = 5uS
       goto $+1         ; + 2uS = 7uS
       goto $+1         ; + 2uS = 9uS
       goto $+1         ; + 2uS = 11uS
       goto $+1         ; + 2uS = 13uS
       bsf IRTX,PIN     ; 1uS, LED=on
       decfsz _Cycles,f ; + 1uS = 10S
       goto _Pulse40    ; + 2uS = 12uS
       return           ; Return to caller
    ' Generate "Cycles" number of ~38.4kHz pulses
    _Pulse38
       nop              ; + 1uS = 10uS
       decfsz _Cycles,f ; + 1uS = 11S
       goto _Pulse38    ; + 2uS = 13uS
    OverFreq:
    Create one for whatever IR carrier freq you need, and just call them like this with PBP;
    @ #define IRTX GPIO  ; Define port to use for IR out
    @ #define PIN 2      ; Define port pin to use for IR out
    INCLUDE "Freq.inc" '
      GPIO.2 = 1       ' IR LED off   -----|<|----/\/\/\----+5
      TRISIO.2 = 0     ' Output for IR signal
      CMCON = 7        ' Comparators disabled
      ANSEL = 0        ' A/D disabled
      Cycles = 60      ' min 1, max 255
      CALL Pulse38
      GOTO Main
    At 4MHz you won't be spot-on for every carrier frequency, but it will be close enough to work with pretty much any off-the-shelf IR receiver.
    -Bruce
    tech at rentron.com
    Aug 2005
    Michigan, USA
    Have you considered using an 8-pin 12F683 and generating a 38-KHz PWM signal output in the background? Use a interval counter and turn the PWM output on or off at the correct intervals by setting the CCPR1L duty cycle register to 50% or 0%.
    Regards, Mike
    Apr 2010
    Thanks for all the help and suggestions.
    Bruce, I tried your suggestion and it works great!
    Alan Parekh
