As an EasyPic6 user, I posed the same question to Microelektronica in a ticket to their tech support. It took a couple of interactions, but they do have a solution if you are using the extended ports on the EasyPic6 with one of their ProtoBoard. Here are my exchanges with them in reverse chronological order if you are interested.
You can use EasyPROTO for your application.
http://www.mikroe.com/en/tools/easyproto/
Best regards
Slavisa Zlatanovic
mikroElektronika [Support Department]
As I said in my previous email, the 5V-3.3V translator won't work when using more than one of the port expanders with PROTOboard.
Another approach that might solve my problem would be using flat cables from all 3 ports of the EasyPic6 to the PROTOboard, which would then permit insertion of the 5V-3.3V translator into the circuit for just the single port that I need to convert the voltages for. I see on your web site your product "Flat Cable 1 Extra Development Board", but it has female connectors on both ends. What I would need is a flat cable with female on one end (for connection to the EasyPic6) and male on the other (for connection to the PROTOBoard)....do you have such a product? If so, what is the price?
Regards, JE
-----Original Message----
From: mikroElektronika Support Center [mailto:[email protected]]
Sent: Monday, March 29, 2010 2:05 AM
To: [email protected]
Subject: [SUPPORT #SHW-490341]: How to get MCU logic levels to 3.3 volts for LCD compatibility?
Hi!
We recommend you to use our 5V-3.3V Voltage Translator.
http://www.mikroe.com/en/tools/voltran5/
That way you will not have to worry about different voltage levels.
Best regards
Slavisa Zlatanovic
