Long Lines for 1-wire iButton DS1992
Results 1 to 5 of 5
    Sep 2006
    Default 1-Wire
    If it works where is the problem?
    Maxim has a few articles on such cases with mosfet drivers etc. But I don't think you need them.
    I'm afraid that the Pullup is to small???
    The port can sink 20-25mA. At 5volts/550 that is 9,09mA. So you are absolutely safe.
    But even if you short the output (Not recommended though) nothing will happen as the outputs are fets that limit the current as he temp rises.
    Sep 2006
    Smile Thanks
    Thank you very much Ioannis
