Include Files for some Routines
Results 1 to 3 of 3
    Miami, Florida USA
    Default Include Files for some Routines
    Hi all,
    If the feature that I'm wishing for is already available in PBP, then my apologies .
    In one of the projects that I'm currently working on there is a long initialization procedure (~200 lines of code) for a TFT display that I must include in my PBP main program. Then, I was thinking that it would be very nice if I could do something similar to
    INCLUDE "modedefs.bas"
    For example, something like
    INCLUDE "MyTFT_Init.bas"
    Then, I would call the routine in this "MyTFT_Init.bas" file to initialize my TFT display and that way I don't need to have this long procedure taking up space in my main PBP program. I know some C language, but I don't know any assembly.
    Is this feature that I'm wishing for already available in PBP? Can I create a routine in another BAS file and call it from my main PBP program?
    Thank you all for your ideas and comments. Sincerely,
    You bet Robert, it is already available in PicBasic.
    You can add any code you want as an include. Normally they are named .inc, .bas, or .pbp. Just like in pbp, you can use PicBasicPro, or assembly in the include files.
    Here is a detailed thread about include files: http://www.picbasic.co.uk/forum/showthread.php?t=2400
    Walter
    Miami, Florida USA
    scalerobotics,
    Thank you for your reply. I will take a look at the thread you mentioned in your post.
