Found it...!
I added a 100K resistor between RA2 and +5, not sure if 100K is the perfect value but it works.
Thanks for the guidance.
Mike
Found it...!
Mike
Now I am starting to feel psycho responding to myself that many times but after putting my glasses on, it is a 180 ohms I have there and the delay is now 80nS, tried 1k and got 120nS, also tried direct but no go.
So 80nS is acceptable and way better than 4uS.
If anyone can figure out a way to make it 0 delay that would make things just perfect.
Mike
You won't make it zero. There's hardware between the input and output, and it takes time for the little electrons to wiggle their way through very tiny wiring. You could always strap RA2 directly to +5, but it won't get much better than that. The performance limits are somewhere in the back of the Datasheet.
I tried to connect RA2 direct to +5 but that gives me a straight 5 V at RA3
But its good now, I have improved the range, driving one side of the Tx was 10 feet and now having the inverted output I get 28 feet.
I will probably improve more when I get to the mechanical aspect.
Thanks for your help.
Mike
