One Circuit, Three Different Voltage Levels
Results 1 to 10 of 10
    Miami, Florida USA
    Default One Circuit, Three Different Voltage Levels
    Hi all,
    I need some help here . I have a project with a PIC18F4550 that uses USB interface to communicate with a PC. Also, the PIC interfaces with a color GLCD and an SD card. I'm planning to use a rechargeable battery. I have three different voltage level requirements for this project. The voltage levels that I need are as follows
    • 3.0V for the GLCD Vin and I/O ports, and also for the SD card.
    • 5.0V for the USB interface.
    • 12.0V for the GLCD backlighting. The backlight voltage feed uses a 220 Ohms resistor in series.
    I would like to keep the circuit as simple as posible with a minimum number of components. That is why I would prefer not to use two voltage regulators, 3V and 5V.
    What is the best way to do this? Can I run the PIC at 3.0V and use a level converter for the USB interface on D- and D+? How do I go up to 12.0V for the GLCD backlight? What chips can I use?
    Thank you for your help.
    Hi Robert,
    Several options available here, depending upon board real estate, cost, power consumption . . . Simple, power hungry way is a voltage divider down from a regulated 12v supply.
    Or you could set up HPWM as a charge pump to get 12V from 5 v
    Or probably the easiest, and cheapest is separate regulators, or hybrid with one of the above choices.
    Using battery power, I think I would use switching regulators for each voltage, and only power them up as needed.
    Might look into not needing the 5 volts if you are just sending data on the USB and not planning to power a device.
    May 2008
    Italy
    Can you replace the 220 Ohms resistor on the GLCD?
    If yes, then you can experiment to turn on the backlight with 3 or 5 volts, if it works you have solved half of your problem.
    Al.
    Miami, Florida USA
    Thank you all for your response.
    mackrackit,
    I'm not powering any devices with the USB host 5 volts, but I'm almost 100% sure that the signal comming in and out of D- and D+ on the PIC18F4550 needs to be 5V. That's why a voltage level converter is needed, but I don't know which chip is appropiate.
    Aratti,
    The GLCD backlight voltage must be around 9.3 Volts. But, the datasheet recomends to use 12V with a current limiting resistor of around 220 Ohms.
    Joe S,
    The circuit is going to be fed from a rechargeable battery, and a voltage divider will drain a battery very quickly. The battery that I will use is probably a 6.0V lithium battery. I read somewhere that there are some LED driver chips that give you 12V from a 5V or 3V voltage input. But, if this is true I don't what chips these are.
    Again, thank you all for your ideas.
    Check out figure 17-1 in the 4550 data sheet.
    Just run the 4550 at 3.3 volts and save one regulator.
    Miami, Florida USA
    Nice! . So, the USB module works with 3.3V. Everything starts to make sence now. Thanks a lot. That saves me the use of an extra regulator and some voltage level converters.
    Now, for the GLCD backlighting I'm planning to use something like this power booster DC/DC step-up converter. I just need to find the right chip for what I need. Has anybody used these DC/DC step-up converters before? Thanks again.
    http://www.onsemi.com/pub_link/Collateral/CAT4238-D.PDF
