Problems starting an 18F8720
Results 1 to 9 of 9
    Apr 2010
    Default i will try it this evening
    Thanks for the reply i will give it a try when going home,
    i know adcon can give unexpected behavior sometimes, but i did'nt know it can simply avoid you pic to run a simple blink led.
    Perth, Australia
    if the pin the LED is on is also an AD pin, then yes it will stop it if that pin is configured for analog use.
    Also, there is a problem in your code if you want the LED to blink. HIGH PORTA.1 will put port A, pin 1 high and LOW PORTA.0 will put port A, pin 0 low and thats where they will stay. Nothing will blink.
    Apr 2010
    my mistake in the code i typed over, i tried with pins on almost every port.
    B, H, A with the same result always. Not blinking. Therefore i have doubts over the device, how can i troubleshoot this ...
    Perth, Australia
    Hard to say without more information like the entire code, config settings and hardware setup. Are you using an external OSC?
    Apr 2010
    Default The card
    This pic is on a card with an osc onboard of 6mhz supposed to be ran on 24mhz thanks to hsppl.
    Here is a pdf of the card, (it's in thai) but the last 2 pages are the wiring diagrams.
    http://www.steitec.net/media/product...1249723519.pdf
    Perth, Australia
    Can you post your code and config settings.
    Apr 2010
    Default Strange
    Came back home and done it over again, played a bit with the config bits and it started to blink with and without adcon, one config bit i have removed was LVP .... that should not interfere execution.;.. but ok it works now thanks for the support.
