Quickest way to do an If val1 = val2 with Word variables
Results 1 to 14 of 14
    Feb 2003
    Sydney, Australia
    Default Quickest way to do an If val1 = val2 with Word variables
    Hi There all,
    I am working on a program that has an interrupt routine that need to do a very fast "if val1 = val2 then", but it seems to be taking a long time for the if..then to evaluate. Based on my measurements it is taking 60uS.
    Yes I said 60uS ! This is a 16f1936 running at 32MHz. Problem is that I am in a serial interrupt routine where each character is only 36uS, so I need to see if I am at the chosen channel and if so to load it into a buffer.
    I have the buffer code and it works as is, but at higher refresh rates I am loosing data and it looks like I am overflowing the buffers in the uart.
    What I really want to know is taking hints from this thread : http://www.picbasic.co.uk/forum/showthread.php?t=12635
    is there an easier way to compare word1 to word 2 and to do something if they are equal ??
    Driving me mad !!
    bill
    val1 VAR WORD
    val2 VAR WORD
    SLOW
    IF val1 = val2 THEN SomeWhere
    FASTer
    IF val1.HighByte = val2.HighByte THEN
        IF val1.LowByte = val2.LowByte THEN
            GOTO SomeWhere
    Feb 2003
    Sydney, Australia
    Hi Darrel,
    Nope - same time. 60uS.
    Think something weird might be going on here - might do some bare bones code.
    bill.
    Wink
    Hi, Bill
    could you provide the "Guilty" interrupt code ???
    easier to talk about real matter ...
    PS: http://www.picbasic.co.uk/forum/show...3&postcount=13 ... obviously raises some questions !!!
    Jun 2007
    Sydney, Australia
    Hi Bill,
    How about:
    if (A XORNOT B) then something
    XORNOT is a logical comparison testing for equality basically...
    Phil.
    Duck sensing headlights! Quack, quack, Bing!
    Feb 2003
    Sydney, Australia
    Interesting thoughts.
    I think its time to do some bare bones code to see which works out to be quicker.
    Bill.
    Feb 2003
    Sydney, Australia
    Smile
    Hi Guys,
    So I finally got some time to do some testing.
    I have an admission to make - the 60uS I was seeing that started this whole process off seemed to be caused by failing to set my debug output that was watched with the logic analyser to a known state if the values didn't match...
    What I did yesterday was run a few different comparison scenarios to see what sort of timing you got. Remember this is a 16f1933 running at 32Mhz, so instruction time is about 0.5us.
    What I am doing is comparing the address I want to grab with the current position in the incoming data stream. I reset a counter when I see a header and then count each data packet coming in. When the address matches the count I receive the next three values into a buffer that the main code loop processes. The address can be a value from 1 - 512 so I need to use word variables.
    Doing an if..then compare with two word variables takes 5.125 us
    dbg_out = 1 ' set my debug line high for timing test
    if current_position = current_add then
    ' do the buffer loading
    dbg_out = 0
    Doing an if..then highbyte and lowbyte compare takes 2.125us
    if current_position.highbyte = current_add.highbyte then   ' 2.125 us
      if current_position.lowbyte = current_add.lowbyte then
    dbg_out = 0
    Doing an XORNOT compare takes 4.125us
    if (current_position XORNOT current_add) then
    dbg_out = 0
    Doing an XORNOT Lowbyte Highbyte compare takes 7.625us
    if (current_position.highbyte XORNOT current_add.highbyte) then
     if (current_position.lowbyte XORNOT current_add.lowbyte) then
    dbg_out = 0
    So it looks like Darell was correct that the fastest way is a If..Then with Lowbyte / Highbyte.
    Bill.
    Last edited by bcd; - 22nd April 2010 at 02:08. Reason: Put the correct CODE demarkers in.
    Talking
    In the comparissons you have made, were the two variables (either word or byte) equal?
    That is important in your second case with the two If-Then's. In case the first if-then fails it will exit sooner.
    Jun 2007
    Sydney, Australia
    Ioannis has a point (but maybe not the one I initially thought he was making... ).
    What about:
    if (a.highbyte xornot b.highbyte) and (a.lowbyte xornot b.lowbyte) then
    ' do stuff
    This removes an if-then macro/template from the timing equation.
    You will always be making two comparisons to confirm equality, but there will be an overhead of potentially one unneccessary compare when a and b are not equal (but, hey, at least you know for sure how fast the code operates)
    I'm sort of attached to xornot now...don't want to let it go...
    Phil.
    and I wish I had a stickfigure that did the 'dance of the happy programmer'
    The separate IF/THEN "templates" make it quicker.
    When you have multiple AND's/OR's/XORNOT's etc. on the same line, then intermediate variables (T1+) are used to keep track of each "Term".
    And T1+ variables are WORDs (LONGs for PBPL).
    So while it looks shorter in the code listing, it really takes longer.<hr>
    Well, I was trying to keep it straight PBP.
    Which is why the previous example only got a "FASTer" rating.
    But, if you want the "FASTest", ya gotta drop down to ASM with bank0/system variables.
    val1   VAR WORD BANK0 SYSTEM
    val2   VAR WORD BANK0 SYSTEM
        movf    val1+1, W
        subwf   val2+1, W
        btfss   STATUS, Z
        goto    NotEqual
        movf    val1, W
        subwf   val2, W
        btfss   STATUS, Z
        goto    NotEqual
        L?GOTO  _UserRoutine  ; val1 = val2
    NotEqual
    UserRoutine:
    ;... yadda yadda ...
    Of course, someone will probably find a "FASTest.er" way ... I hope. <hr>
    ADDED:
    The above can only be used once without modification.
    But if you turn it into a Macro, it can be used multiple times, with different variables. (as long as they're in bank0)
    DT_EQUAL  macro v1, v2, label
      local NotEqual
        movf    v1+1, W
        subwf   v2+1, W
        btfss   STATUS, Z
        goto    NotEqual
        movf    v1, W
        subwf   v2, W
        btfss   STATUS, Z
        goto    NotEqual
        L?GOTO  label  ; v1 = v2
    NotEqual
    ;--- usage -------------------------
    @ DT_EQUAL  val1, val2, _UserRoutine  ; IF val1 = val2 THEN UserRoutine
    UserRoutine:
    hth,
    Jan 2006
    Istanbul
    Darrel,
    Using the same way, (or a similar logic) can it be done to compare two words whether they are smaller or bigger?
    Highy byte can always be bigger but low byte can be smaller.
    ___________
    Jan 2006
    Istanbul
    I now see that my question already has the answer in itself.
    Just compare the high byte, skip comparing the low; so in fact no need to compare the whole word.
    Mar 2010
    Austin, TX
    Than's not a dancing stick figure, that's the skeleton of the internet dancing baby.Name:  dance.jpg
    PickyBiker says, "Riding a motorcycle eases programming frustration".
