How do I use DEBUG ?
Results 1 to 14 of 14
    Feb 2005
    Toronto, Canada
    Question How do I use DEBUG ?
    hello, odd question, but I was previously a Basic Stamp user before using PIC's and I got used to having the debug command every now and then.
    can I do that with PBP? I read in the manual on pg 54, that it sends out the serial data. and to hyperterminal (which is thankfully still included with xp) but how do I hook it all up? and is there an option to have a DEBUG screen WITHIN PBP? (anyone used the stamp and know what I'm talking about?)
    I'm not really all that interested in using the LCD debug, I'd much rather simply use one pin on my pic and have a pc screen.
    thanks!
    PICMAN's Avatar
    PICMAN Guest
    i believe serout is the comand you refrence,
    from my experiance, almsot every thing i learned on basic stamp i relearned for pic, as i said im only using this bs2 , cause i dont have the $ for all the parts i need for pic, and dont want to blow usefull ports on a pic when i could fry my bs2 ,, which in my opinion is useless.
    but i believe serout is the comand, the pbp manual has numeous minimal configurations,, circut drawings, to run a pic, to have serial conectivity, reset butons, u name it the pbp manual has a drawing,
    im sure steve will tell you more , but since i was here i figured id give ya some where to start reading
    Feb 2005
    Toronto, Canada
    acctually, there's a command called DEBUG. I'm more interested in that. but thanks picman
    PICMAN's Avatar
    PICMAN Guest
    well ,, again, the pbp manual, has decent explanitions of comands, do you have a copy?
    Feb 2005
    Toronto, Canada
    yes, and I've read it, pg54 as stated, I'm just wondering if anyone has a better setup to getting the info on screen.
    as asked, I'd like to see the DEBUG info in PBP compiler, or in microcode studio if possible.
    this is not covered in the manual.
    PICMAN's Avatar
    PICMAN Guest
    yeh i just skimmed the whole pbp manual, didnt see debug, ive got a diferent one then you apearantly,
    O.k.. DEBUG in PBP is about the same than SEROUT BUT it take less of your code space. If you want to use DEBUG you'll have to define few things before it work properly to send data to your PC without any kind of MAX232 or else inverter chip
    1. set the baudrate
    DEFINE DEBUG_BAUD 2400
    2. set inverted mode
    DEFINE DEBUG_MODE 1
    3. set the DEBUG serial out pin
    DEFINE DEBUG_REG PORTB
    DEFINE DEBUG_BIT 0 'These two line will set your debug out on the PORTB.0
    Once its done you'll be able to send your data in serial to your PC with
    DEBUG #MyVar
    this will send the ascii representation of MyVar value.
    If you want to send with SEROUT on PORTB.0 at 2400 baud inverted
    SEROUT PORTB.0,4,[#Myvar]
    Both of the above will work with a simple 1k in serie with the PIC to the pin2 of your DB9 connector.
    TRISB=0
    DEFINE DEBUG_MODE 1
    MyVar var byte
    clear
    start:
         DEBUG "MyVar=",#MyVar,13,10
         if MyVar<255 then
              MyVar = MyVar + 1
              Myvar = 0
         goto start
    You can monitor everything in the MicroCode Studio Serial window or in Hyperterm, RealTerm or else terminal program.
    Feb 2005
    Toronto, Canada
    WOW! WICKED!! thanks man!
    debug was the final and LAST reason I was hanging onto my Basic Stamp2 for prototyping. time to sell it and say goodbye to it forever!!
    oh, also, just outa curiosity, is there any preferance as to what pin the debug is used on? porta or B?
    No. since your selected pin can be an output and it's not an open drain type (like many RA4) it will work without anything else than 1 resistor.
    Trent's Avatar
    Trent Guest
    Default More questions about DEBUG command
    1. set the baudrate
    DEFINE DEBUG_MODE 1
    DEBUG #MyVar
    TRISB=0
    DEFINE DEBUG_MODE 1
    MyVar var byte
    clear
    start:
         if MyVar<255 then
              MyVar = MyVar + 1
              Myvar = 0
         goto start
    What does
    do? What is the 13, 10?
    Thanks- Trent
    Mar 2005
    Iowa, USA
    Trent -
    The 13,10 are the decimal equivalents of Carriage Return (CR) and Line Feed (LF) control characters. So each time you send the command to hyperterminal it will be nice and neat on seperate lines.
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    One question concerning debug command.
    With which BAUD rates can it be used ?
    Thank's Dave
  1. N-Bit_MATH
    Last Post: - 16th December 2010, 15:48
  2. Wireless using debug.
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 18th January 2010, 15:53
  3. About USB
    By dias11 in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2009, 21:41
  4. debug not working with MPASM assempler
    By santamaria in forum mel PIC BASIC Pro
    Last Post: - 4th March 2009, 08:51
  5. Data EEPROM gets clobbered during programming
    Last Post: - 18th July 2008, 03:46
