Using div32 to get decimal numbers
Results 1 to 8 of 8
    Apr 2010
    Post Using div32 to get decimal numbers
    Ladies and Gentlemen,
    I have a small problem: I need to display the volume of water that is being fed by a flow transducer to PIC16F877A.The transducer outputs square pulses at 65 pulses per litre,meaning 1 pulse= 0.0154 litres.I can successfully read 65pulses/litre and display on LCD sreen.However,I need more accuracy than that,so I need to count at resolution of 1l1pulse per litre.Now the problem is the floating points.
    I need help using Div32 to count and display
    Thank you
    Clinton
    Wink
    hi, clinton
    no difficulties...
    suppose you won't count more than 1008 liters ( 65535 pulses ...); liters is a WORD !
    1) calculate liters
    liters = pulses/65 ... obvious
    2) calculate decimals
    Tmilliliters = ((pulses // 65) *10000)/65
    centiliters = DIV32 100
    here we take the pulses count remainder ( less than 1 liter ... ), multiply by 10000 and divide per 65 to get 1/10,000 liters; this number is an integer and respects the sensor conversion ratio.
    then result is truncated to centiliters to keep a 0/ -1 digit ( or centiliter ) calculation precision ... and resolution.
    Why centiliters ??? ... simply because sensor counts per 1.54 centiliter increment ... shown milliliters would only be virtual ... hence FALSE ! ( but our calculation is true !!!)
    3 ) print result
    Pulsout $FE,1 ,dec Liters,"." dec3 centiliters
    here it is ...
    Apr 2010
    Default Using div32 to get decimal numbers
    Thank you Alain
    I'll try the coding
    Apr 2010
    I have written the code as follows below,but the output is so fast,I think its giving me millilitres rather than litres...How do I modify it
    W VAR BYTE
    W1 var WORD
    W2 VAR WORD
    W3 VAR WORD
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTD
    DEFINE LCD_RSBIT 1
    DEFINE LCD_EREG PORTD
    DEFINE LCD_EBIT 2
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    W=0
    W1=0
    W3=0
    PAUSE 1000
    MAIN:
    IF PORTC.2=1 THEN
    W=1
    FOR W = 0 TO 65
    NEXT W
    W1= W1 + (W/65)
    W2= ((W1 // 65) *10000)/65
    W3= DIV32 100
    LCDOUT 254,1
    LCDOUT DEC W1, ".", DEC W3, "L"
    GOTO MAIN
    Not sure what your trying to do but it looks like perhaps your NEXT W should be moved to between the LCDOUT and the ENDIF statements. Then, if you want to see it count on the display you'll probably need a short Pause in there a well.
    Wink
    Hi, Clinton
    @ first your counting method is wrong ... you should count transitions ( L> H i.e.) of your output sensor.
    @ second ... what's the reason of the " For w = 0 to 65 ..." loop ???
    @ third ... ----------------d°----- " W1 = W1 + W/65 " ???
    once that tied ... display should slow down a bit ...
