Using div32 to get decimal numbers
Results 1 to 8 of 8
    Apr 2010
    Post Using div32 to get decimal numbers
    Ladies and Gentlemen,
    I have a small problem: I need to display the volume of water that is being fed by a flow transducer to PIC16F877A.The transducer outputs square pulses at 65 pulses per litre,meaning 1 pulse= 0.0154 litres.I can successfully read 65pulses/litre and display on LCD sreen.However,I need more accuracy than that,so I need to count at resolution of 1l1pulse per litre.Now the problem is the floating points.
    I need help using Div32 to count and display
    Thank you
    Clinton
    Wink
    hi, clinton
    no difficulties...
    suppose you won't count more than 1008 liters ( 65535 pulses ...); liters is a WORD !
    1) calculate liters
    liters = pulses/65 ... obvious
    2) calculate decimals
    Tmilliliters = ((pulses // 65) *10000)/65
    centiliters = DIV32 100
    here we take the pulses count remainder ( less than 1 liter ... ), multiply by 10000 and divide per 65 to get 1/10,000 liters; this number is an integer and respects the sensor conversion ratio.
    then result is truncated to centiliters to keep a 0/ -1 digit ( or centiliter ) calculation precision ... and resolution.
    Why centiliters ??? ... simply because sensor counts per 1.54 centiliter increment ... shown milliliters would only be virtual ... hence FALSE ! ( but our calculation is true !!!)
    3 ) print result
    Pulsout $FE,1 ,dec Liters,"." dec3 centiliters
    here it is ...
    Apr 2010
    Default Using div32 to get decimal numbers
    Thank you Alain
    I'll try the coding
    Apr 2010
    I have written the code as follows below,but the output is so fast,I think its giving me millilitres rather than litres...How do I modify it
    W VAR BYTE
    W1 var WORD
    W2 VAR WORD
    W3 VAR WORD
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTD
    DEFINE LCD_RSBIT 1
    DEFINE LCD_EREG PORTD
    DEFINE LCD_EBIT 2
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    W=0
    W1=0
    W3=0
    PAUSE 1000
    MAIN:
    IF PORTC.2=1 THEN
    W=1
    FOR W = 0 TO 65
    NEXT W
    W1= W1 + (W/65)
    W2= ((W1 // 65) *10000)/65
    W3= DIV32 100
    LCDOUT 254,1
    LCDOUT DEC W1, ".", DEC W3, "L"
    GOTO MAIN
    Not sure what your trying to do but it looks like perhaps your NEXT W should be moved to between the LCDOUT and the ENDIF statements. Then, if you want to see it count on the display you'll probably need a short Pause in there a well.
    Wink
    Hi, Clinton
    @ first your counting method is wrong ... you should count transitions ( L> H i.e.) of your output sensor.
    @ second ... what's the reason of the " For w = 0 to 65 ..." loop ???
    @ third ... ----------------d°----- " W1 = W1 + W/65 " ???
    once that tied ... display should slow down a bit ...
    Apr 2010
    ok..
    1- the loop, For W = 0 To 65, I meant to count pulses for 1 litre(65 pulses=1litre)
    so the value I would be storing in W1 will be(0+1), followed by (1+1), then (2+1) and so on.. every 65 pulses.
    The objective is to count litres and display the value on LCD.I realised that count by litres is not good since, e.g. 1 cup of water is not a litre,so I would miss that count.
    That is why I wanted to count at a better resolution of 1 pulse(=0.0154litres).
    I hope you understand my objective better now...
    Thanks for the input, it is appreciated.
    Looking forward to more help
    Apr 2010
    Quote Originally Posted by nkwankwe View Post
    ok..
    hey..i cant seem to get anything right,maybe if you could write me a sample code,I'ld appreciate that
