Help with pic16f690 -max232cpe
Results 1 to 2 of 2
    Apr 2010
    Question Help with pic16f690 -max232cpe
    So i started to try out some serial com and after alot of struggling i have gotten it almoste to work.
    i have pickit2 with pic16f690 and a demoboard with max232.
    max232:
    pin 1 & 3 - 1uf
    pin 4 & 5 - 1uf
    pin 2 - 1uf to vdd
    pin 15 - 1uf to gnd
    and gnd to vdd 1uf
    so i have been able to recive text on my computer from the pic but it's somehow malformed.
    i try to send "Hello World", 13, 10
    and i get
    Hello0World<(8A)>
    when i stop the pic i recive the space and cr and lf
    when i make the pic hserout the hserin i returns random alphas or signs.
    my current code is as follows:
    'intcon=0 ' Interrupts disabled
    cm1con0=0 ' Comparator 1 disabled
    cm2con0=0 ' Comparator 2 disabled
    'cm2con1=0 ' Comparator 2 disabled
    ANSEL=0 ' Pins to be Digital
    ANSELH=0 ' Pins to be Digital
    Include "modedefs.bas"
    DEFINE HSER_RCSTA	90h
    DEFINE HSER_TXSTA	24h 'sets bergh = 1 or 20h sets = 0
    DEFINE HSER_BAUDCON 0h ' 0h
    DEFINE HSER_BAUD	9600 '16468
    DEFINE HSER_SPBRG	25
    'DEFINE HSER_CLROERR 1
        hserout ["Hello World", 13, 10]
    and i cant figure out why!
    im using picbasic with MC studio and MPASM
    Please HELP
    Mar 2010
    Minnesota, USA
    I have never used HSEROUT before but I use SEROUT.
    Try this code just change your output pin from PORTB.0 to what ever one you are using:
    Baud   con     2                           ' Define serial mode
       Serout PORTB.0,Baud,["Hello World",13,10]
    If the "Baud con 2" doesn't work change it to "Baud con 6"
    This is the Mode - 2 is 9600 TTL True and 6 is 9600 TTL Inverted
