6 Mhz Oscillator
Results 1 to 3 of 3
    Apr 2010
    Default 6 Mhz Oscillator
    I've aquired a card with a pic 18f8720 on it, so far so good.
    The model is supported etc, but that card has a 6Mhz crystal.
    And when i consult the PBP manual i see that supported oscillators are 4 and 8, etc
    Is there any work around for this?
    Should I change the cristal on the card ? Go for 10, 8 or better 4 ?
    (yekes, card is compact and double sided)
    Run it with OSC 4 ?
    I need to do some I2C later on, will that have any side effects ?
    Wink no mod needed ...
    Hi, Sebastien
    IF you intend to use PBP ... I would recommend you to simply enable the HSPLL mode ( 4x Xtal frequ. ) ... in the Chip CONFIG lines.
    You just will have to declare 24 Mhz as a clock frequency ( DEFINE OSC 24 ) ...
    the only backdraw will be for " slow PWM " generation ... 1465 Hz will be a minimum ! and some little limitations with the Pulsin, RCTime ...not frequency compensated command.
    No need to modify your card, then ... if 6 Mhz is not in use for another chip on the card !!!
    Apr 2010
    Default Great, it explains a lot.
    I never heard about the HSPPL, this explains why this card is delivered with 6 mhz crystal the lower model got a 10, i did'nt understood why a much better pic got a lower crystal. Now I got it 24mhz is nice for that card.
    Merci beaucoup
