Software reset
Results 1 to 17 of 17
Thread: Software reset
    not sure of it... humm... what is the purpose of this software reset?
    What do you expect?
    Do you set all your registers at the begining?
    Sure you can set all register to the default POR before the goto reset vector ... but those registers are not all to zero... see datasheet for POR setting of each registers.
    Feb 2005
    Portugal
    The ideia in doing the software reset it´s that:
    I have a "security command" and when this contact is closed the circuit work´s normally, but when the contact opens I don´t want that the circuit work´s, but when the contact closes again all my registers goes like it seems we remove the power, like it was the first time we were running the program...
    What I´m thinking to do is modify the value on the registers that I've modified and put them at zero or to the value that had at the beginning!
    If you just need to clear all RAM (variables) then use the CLEAR command.
    If you want to start over from location 0 simulating a power-up condition, and clear RAM without a hardware reset, then use;
    @ clrf PCLATH
    @ goto 0
    And place CLEAR as the first BASIC instruction.
    If you have a security check routine that needs to clear RAM when a switch changes state, use the CLEAR command on entry to the routine.
    Lots of options.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Feb 2005
    Portugal
    Thumbs up It works...
    Thank´s, your solution works.
    I was forgetting the clear command...
    The code to do a software reset is:
    clear
    @ clrf PCLATH
    @ goto 0
    Best regards
    Leonel
    Worayoot's Avatar
    Worayoot Guest
    Thank you
    @ clrf PCLATH
    @ goto 0
    I use with 12F work very well
  1. IC12F508 with Internal Oscillator and Software Reset
    By karan123 in forum mel PIC BASIC Pro
    Last Post: - 2nd October 2009, 17:13
  2. Software Stack
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 18th December 2007, 11:04
  3. Replies: 3
    Last Post: - 26th November 2006, 22:47
  4. How to reset the pic by software ?
    By Shamir in forum mel PIC BASIC Pro
    Last Post: - 18th October 2006, 17:43
  5. Software Driven Reset Routine
    Last Post: - 11th April 2005, 01:53
