Software reset
Results 1 to 17 of 17
Thread: Software reset
    Feb 2005
    Portugal
    Default Software reset
    There are any way to do a software reset, not an hardware reset?
    By software only ... no.... and yes.
    If you connect one extra i/o to your MCLR pin... yes
    Feb 2005
    Portugal
    Default MCLR pin
    What your saying is to connect, for example, porta.1 to MCLR pin and "write" porta.0 = 0 to make a software reset?!
    yep. just make sure your PORTA.1 is set to high or as input when you boot the pic and that's it.
    EDIT: i don't know if it's working but i just read my 18F2320 datasheet about the STKPTR register. Probably you can set the stack register full and do few gosub to get a Stack Full Resets too. never tested it. i'll try this now and let you know.
    Talking
    Mouhaha it's working
    ' program to perfom an software reset
    ' PIC18F2220
    DEFINE LOADER_USED 1
    DEFINE OSC 20
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_BAUD 9600
    loop var byte
    begin:
    STKPTR = 0 ' clear Stack resets bits
    hserout ["software RESET",13,10]
    start:
        for loop = 10 to 0 step -1
            hserout ["reset in ",dec loop,13,10]
        next
        STKPTR = $FF ' full stack pointer
        gosub there
        goto start
    there:
         hserout ["I'm supposed to be die now ;o("]
         gosub there2
    there2:
         hserout ["I'm supposed to be die now for the 2nd time ;o("]
         gosub there3
    there3:
         hserout ["I'm supposed to be die now for the 3rd time ;o("]
    it never jump to 'there' or 'there2' and for sure 'there3'
    cool stuff!
    if you're using an 18F type pic, you can just use the reset command.
    @ reset
    if using a 16F,
    asm
      clrf PCLATH
      goto 0
    endasm
    Darrel
    @ reset
    yup... always read the whole datasheet.
    Feb 2005
    Portugal
    Default Bad code
    The code doesnīt make a software reset to all registers
    @clrf PCLATH
    @ goto 0
    What i did wrong?
    Leonel Monteiro
    well i'm not sure to agree 100% about that method. Are you still using the 18F series?
    looks no 'cause you must use @ reset
    did you try with the i/o reset method?
    Feb 2005
    Portugal
    Default 16f
    I'm using 16F so the @reset itīs not possible.
    I didnīt try the I/O method because my PCB is done...
    my assumption is by using this method, it jumps only to the reset vector. So it doesn't produce any effects on the registers... so the i/o style should be considered.
    Feb 2005
    Portugal
    Default Put all registers to zero
    Yes, I agree with you...
    What do you think the ideia to do software reset putting all my registers to zero. Itīs easier and i havenīt to use the I/O method
    not sure of it... humm... what is the purpose of this software reset?
    What do you expect?
    Do you set all your registers at the begining?
    Sure you can set all register to the default POR before the goto reset vector ... but those registers are not all to zero... see datasheet for POR setting of each registers.
    Feb 2005
    Portugal
    The ideia in doing the software reset itīs that:
    I have a "security command" and when this contact is closed the circuit workīs normally, but when the contact opens I donīt want that the circuit workīs, but when the contact closes again all my registers goes like it seems we remove the power, like it was the first time we were running the program...
    What Iīm thinking to do is modify the value on the registers that I've modified and put them at zero or to the value that had at the beginning!
    If you just need to clear all RAM (variables) then use the CLEAR command.
    If you want to start over from location 0 simulating a power-up condition, and clear RAM without a hardware reset, then use;
    @ clrf PCLATH
    @ goto 0
    And place CLEAR as the first BASIC instruction.
    If you have a security check routine that needs to clear RAM when a switch changes state, use the CLEAR command on entry to the routine.
    Lots of options.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Feb 2005
    Portugal
    Thumbs up It works...
    Thankīs, your solution works.
    I was forgetting the clear command...
    The code to do a software reset is:
    clear
    @ clrf PCLATH
    @ goto 0
    Best regards
    Leonel
    Worayoot's Avatar
    Worayoot Guest
    Thank you
    @ clrf PCLATH
    @ goto 0
    I use with 12F work very well
  1. IC12F508 with Internal Oscillator and Software Reset
    By karan123 in forum mel PIC BASIC Pro
    Last Post: - 2nd October 2009, 17:13
  2. Software Stack
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 18th December 2007, 11:04
  3. Replies: 3
    Last Post: - 26th November 2006, 22:47
  4. How to reset the pic by software ?
    By Shamir in forum mel PIC BASIC Pro
    Last Post: - 18th October 2006, 17:43
  5. Software Driven Reset Routine
    Last Post: - 11th April 2005, 01:53
