One Circuit, Three Different Voltage Levels
Results 1 to 10 of 10
    mackrackit,
    Thank you for guiding me in the right direction. I did some more research and found out that the internal USB regulator must be turned off. The capacitor at Vusb is not needed anymore and the internal USB transceiver and pull-up resistors can be used in the configuration I'm using. I just need to feed 3.3V at Vusb and Vdd.
    So, I'm running my PIC18F4550 with Vdd=3.3V and the USB peripheral works! I was able to send and receive data from my computer to the PIC.
    As for the GLCD backlight voltage, I have already ordered this chip and the required external components from mouser.com
    http://www.onsemi.com/pub_link/Collateral/NCP5007-D.PDF
    This chip is a backlight LED boost driver. The input voltage range is from 2.7 to 5.5 Volts, so it should work for my application.
    Thank you all again for your help and ideas.
    I think you only read the first line of my post, where I said simple POWER HUNGRY way. You can set a Hardware PWM on your pic and not need that chip you ordered from Mouser, I have used simple 12F chips to do that with pins to spare without using HPWM, so How much easier is using it ? Your money, spend it your way. Cost extra real estate on PCB too.
    Miami, Florida USA
    Joe,
    Thank you for your comments. Yes, I read the part were you talk about HPWM in your post. That would work if I needed to obtain 3.3V from a PIC running with Vdd=5.0V. But in my case I have a 6.0V rechargeable battery and a 3.3V voltage regulator. Somehow, I need to obtain 12V to feed the GLCD backlight.
    Please, take a look at the attached drawing. In the left lower part it says the power requirements for the backligh. It says "Backlight Vf=9.9V, 12.5 mA per side". However, the datasheet recommends to use 12V with a series current limiting resistor. If you don't feed 12V to the GLCD it will not work. Now, do you see why I had to buy a backlight LED boost driver? They cost about $0.70 a piece.
