Serial to USB cable - varying results
Results 1 to 15 of 15
    May 2007
    Quote Originally Posted by Mike, K8LH View Post
    I cut off the connector on the cell phone end of the cable and replace it with a 3.5mm "stereo" plug. I wire up the WHT (phone Tx), GRN (phone Rx), and BLK (ground) wires. I put a matching 3.5mm "stereo" jack on my PIC project boards and I'm in business (no MAX232 or equivalent level shifter IC required). Please note that there is no 5v wire in the cable (bummer!).
    Regards, Mike, K8LH
    Do you know if perhaps other signals are available on this cable - in particular RTS and CTS? Thanks.
    Aug 2005
    Michigan, USA
    Well, it's kind of a "good news" and "bad news" situation, I'm afraid...
    The PL-2303 circuit board on the "business end" of the cable includes pads for 3.3v (<50ma), 5v (<100ma), RTS, CTS, etc. but since the cable is molded you have to cut away the blue plastic molding and the black rubber potting underneath to access to the circuit board. Here's what you end up with;
    It seems that each new generation of clone cables are cheaper then the last. If you check out the original Jonathan Thomson article that caught my attention you'll find that earlier versions of the cable had a removable shell at the USB end and had more wires to work with and so that's kind of a bummer(!).
    Regards, Mike
    May 2007
    Thanks for the info and the link.
