LCD Rolling Odometer Effect
Results 1 to 35 of 35
    Open ASM_INTS.bas and follow the instructions
    ' --- IF any of these three lines cause an error ?? Simply Comment them out to fix the problem ----
    wsave1 var byte $A0 SYSTEM ' location for W if in bank1
    wsave2 var byte $120 SYSTEM ' location for W if in bank2
    wsave3 var byte $1A0 SYSTEM ' location for W if in bank3
    (also, there might be a newer elapsed.bas that uses DT_INTS. Does anyone know where that is?)
    That's here ...
    http://darreltaylor.com/DT_INTS-14/elapsed.html
    Yes, but (I am sure it is right in front of me) I don't see a place to download the elapsed code from there. It is obvious for the INTS-18 though. The link to PBPGroup has an Elapsed that has Include "ASM_INTS.bas" ' ASM Interrupt Stubs, but I am thinking there is one for DT_INTS.
    DOH!
    You're right, there's no download.
    I used to have it in the main .zip file, but it's not there in the latest version.
    I'll put it up again separately.
    Thanks Walter
    Jan 2011
    Skopje,Macedonia
    it's ok,it's working now. I made it.
    Jan 2006
    Slovenia EU
    Default Re: LCD Rolling Odometer Effect
    Darrel,
    I couldn't see your picture on this thread.
    Who can find include file "elapsed.bas"?
    Yeah, screentoaster.com went out of business, and I lost all the video's I recorded.
    A lesson learned about using FREE services .. they're costly in the end.
    You can get Elapsed.bas from here ...
    http://www.picbasic.co.uk/forum/showthread.php?t=190
