Thanks. Incidentally, the datasheet from Digikey for the part number I'm using is incorrect. It didnt show how to connect the RGB backilighting correctly. Good job I double checked by calling New Haven tech support. The pin out was wrong - missing 2 pins and swapping the backlight A and K. Yikes Digikey!!
NHD-0216K1Z-NSRGB-FBW
New Haven did not warn me of any other issues with data sheets. It looks like Digikey has an early version of the correct datasheet that contains errors, as the part number of the device and the datasheet do match. However the data sheet downloaded directly from New Haven is definitely different.
Take a look at page 3 of this link: http://www.newhavendisplay.com/specs...B_FBW-REV1.pdf
And take a look at pages 3 and 4 of this link: http://www.newhavendisplay.com/specs...-NSRGB-FBW.pdf
The second link is from Digikey and pages 3 and 4 clearly show 16 pins, not 18 per the actual device. The correct pinout is pins 16, 17 and 18 are the anodes for red, green and blue respectively. Pin 15 is the cathode pin.
The digikey link shows pin 15 as anode and pin 16 as cathode.
