Using two AtoD channels - they're interacting?!
Results 1 to 4 of 4
    Mar 2009
    Thanks for taking the time to reply.
    I had a look, here's what I found...
    ' ADCIN1X4.BAS
    '  For PIC12F683 and melabs PICBASIC PRO Compiler
    ' Display result of 10-bit A/D conversion on LCD
    Include "modedefs.bas"		' Mode definitions for Serout
    ' Define ADCIN parameters
    Define	ADC_BITS	10	' Set number of bits in result
    Define	ADC_CLOCK	3	' Set clock source (3=rc)
    Define	ADC_SAMPLEUS	50	' Set sampling time in uS
    LCD	Var	GPIO.1		' LCD TX pin
    adval	Var	Word		' Create adval to store result
    	ADCON0.7 = 1		' Right justify result
    	ANSEL = %00111000	' Set AN3 analog, rest digital
    	CMCON0 = 7		' Analog comparators off
    	Pause 500		' Wait .5 second for LCD to init
    mainloop:	ADCIN 3, adval		' Read channel 3 to adval
    	Serout LCD, T2400, [$fe, 1]	' Clear screen
    	Serout LCD, T2400, ["Value: ", #adval]	' Display the decimal value
    	Pause 100		' Wait .1 second
    	Goto mainloop		' Do it forever
    Unfortunately, that example only uses one channel.
    Pretty much after I posted, I sorted my problem (how does that always work then?!).
    Two things were the root of my issue...
    1. I'm using a sig gen, rectifying a sine wave from it & feeding into & low pass filter (the resulting extracted DC level feeds into one AtoD channel) ....I was getting over zealous with the sig gen output amplitude - and the rectified DC level breached 5V - which sends the PICs AtoD results a bit whacky (which is hardly surprising) ...one channels starts seriously impacting the sample from a totally different channel! So Hank makes amental note - be careful with the input voltage magnitude fed into an AtoD pin!
    2. The other problem was that I wasn't allowing sufficient time between using successive AtoD channels - I'm finding that in my setup, it needs at least 30ms between successive AtoD channels 'samples' - hey ho.
    Sep 2007
    USA, CA
    Quote Originally Posted by HankMcSpank View Post
    This is the case with every PIC, and for each and every a/d reading. It is called the "charge time" for the sampling capacitor, and is most often the bottleneck for sampling rates. (Some PICs charge it faster.) With a single channel it is often not noticed because the sampling cap is charged while doing other things, or because you get an "old" reading from the same channel.
