Using two AtoD channels - they're interacting?!
Results 1 to 4 of 4
    Mar 2009
    Default Using two AtoD channels - they're interacting?!
    Have you ever had one of those evenings where everything falls to pieces? Having used AtoD without issue for quite a while, my 12F683 is laughing at me....and now I'm not sure what I know & what I don't know wrt AtoDing!
    Previously, in my newbie ignorance (bliss?), when wanting to use more than one AtoD channel, I was simply doing this (on a 16f690)...
    ADCIN 1, intensity
    pause 2        '
    ADCIN 3, Signal_In
    never had a problem - my AtoD (Seemingly) worked!
    Ok, now I've moved to a smaller (simpler?!) PIC - a 12f683. It's kicking my backside - two nights wasted on the seemingly very simple task of getting two AtoD channels to work correctly.
    Firstly, can I get a really basic question out of the way? (you have to promise not to laugh!)
    when moving between AtoD channels, should I be setting the ADCON register *every* time? (the PICBasic compiler suggests so, so I guess the answer is yes!)
    ie, should I actually be doing this...
        ADCON0 = %10000111 ' select AN1
        pause 50 'wait a bit
        ADCIN 1, intensity ' 'ok, let's Ato D.
        ADCON0 = %10001111 'now move on to a different AtoD channel - AN3
        pause 50  ' let things settle
        ADCIN 3,Signal_In
    in other word, using the ADCCON0 register to move between the different Analogue Channels?
    If so, then how the hell was I getting away with it on my 16f690?
    ok, now to my (latest) immediate problem - if I apply a variable DC level to say AN1 (just for testing to observe the results), moving the test voltage level up/down also affects the AN3 AtoD reading (& vice versa) - eh?
    Now I know you have to wait sufficient time to let things settle when moving between channels, but I'm already pausing a good while before AtoD'ing the next channel - what's going on?
    Have a look at some of the MeLabs examples for the LAB-X4 board & 12F683 A/D.
    http://melabs.com/resources/samples.htm#x4pbp
    I'll bet between these and the data sheet you'll see what the difference is..;o)
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Mar 2009
    Thanks for taking the time to reply.
    I had a look, here's what I found...
    ' ADCIN1X4.BAS
    '  For PIC12F683 and melabs PICBASIC PRO Compiler
    ' Display result of 10-bit A/D conversion on LCD
    Include "modedefs.bas"		' Mode definitions for Serout
    ' Define ADCIN parameters
    Define	ADC_BITS	10	' Set number of bits in result
    Define	ADC_CLOCK	3	' Set clock source (3=rc)
    Define	ADC_SAMPLEUS	50	' Set sampling time in uS
    LCD	Var	GPIO.1		' LCD TX pin
    adval	Var	Word		' Create adval to store result
    	ADCON0.7 = 1		' Right justify result
    	ANSEL = %00111000	' Set AN3 analog, rest digital
    	CMCON0 = 7		' Analog comparators off
    	Pause 500		' Wait .5 second for LCD to init
    mainloop:	ADCIN 3, adval		' Read channel 3 to adval
    	Serout LCD, T2400, [$fe, 1]	' Clear screen
    	Serout LCD, T2400, ["Value: ", #adval]	' Display the decimal value
    	Pause 100		' Wait .1 second
    	Goto mainloop		' Do it forever
    Unfortunately, that example only uses one channel.
    Pretty much after I posted, I sorted my problem (how does that always work then?!).
    Two things were the root of my issue...
    1. I'm using a sig gen, rectifying a sine wave from it & feeding into & low pass filter (the resulting extracted DC level feeds into one AtoD channel) ....I was getting over zealous with the sig gen output amplitude - and the rectified DC level breached 5V - which sends the PICs AtoD results a bit whacky (which is hardly surprising) ...one channels starts seriously impacting the sample from a totally different channel! So Hank makes amental note - be careful with the input voltage magnitude fed into an AtoD pin!
    2. The other problem was that I wasn't allowing sufficient time between using successive AtoD channels - I'm finding that in my setup, it needs at least 30ms between successive AtoD channels 'samples' - hey ho.
    Sep 2007
    USA, CA
    Quote Originally Posted by HankMcSpank View Post
    This is the case with every PIC, and for each and every a/d reading. It is called the "charge time" for the sampling capacitor, and is most often the bottleneck for sampling rates. (Some PICs charge it faster.) With a single channel it is often not noticed because the sampling cap is charged while doing other things, or because you get an "old" reading from the same channel.
