Detect reset by WDT
Results 1 to 7 of 7
    Aug 2003
    Default Detect reset by WDT
    Hi Guys,
    Is there a way to detect in a program whether the program is starting
    from a power on reset or a reset forced by the watchdog timer?
    Cheers, Art.
    Hi, Art
    Yess, of course !
    see the RESET chapter of the Pic® Datasheet you use. i.e. Table 14.4 for the 16F628a ...
    Everything explained for the registers to check.
    Aug 2003
    I didn't see a reset chapter, but did notice that T1CON register is always set
    to zero on powerup, but remains unchanged for any other reset.
    Since I'm not using timer 1, I just set one of the prescaler bits somewhere
    in my program, and then check for the value of T1CON where I want to check
    whether reset was caused by watchdog timer.
    Art,
    Which PIC are you using? On the 18F2431, for example, there's the RCON register which contains the bits telling you what caused the reset. In this case RCON.3 ill be '0' when the WDT timed out and caused a reset.
    Aug 2003
    The chip is an old 16F628.
    Hi Art,
    It looks like STATUS.4 is the bit you want to check, '0' if the WDT caused a reset.
