Question about the switch circuit in the PBP manual
Results 1 to 4 of 4
    Apr 2006
    Michigan
    Default Question about the switch circuit in the PBP manual
    The switch circuit in the PBP manual shows the input pin pulled up through a 10k. That 10k then gets grounded through a switch causing a low on the input. I have noticed that the capacitance of the pin interacting with the trace inductance causes some very fast ringing. I am seeing -2Volts for about 25ns. Why is this ok? I assume it is since this is a very common method for reading switch inputs on micros and various other IC's but it violates the minimum voltage of the pin.
    Sep 2005
    Campbell, CA
    If your trace is short, the ringing is probably caused by your test setup (like a scope probe with a 6" ground lead.
    The PIC probably doesn't "see" that -2V signal. Even if it did, the body diode (on the input of the pin) would clamp it to a diode drop below GND.
    Charles Linquist
    Miami, Florida USA
    Also, to avoid false readings and weird behavior of the switch a pause should always be set after a ground is detected (if a pullup resistor is used). This pause is for debouncing the switch and to let the ringing pass. In an 'ideal' switch you wouldn't need this debouncing pause period, but a real world switch will mechanically oscillate and act strange.
    Wink
    Quote Originally Posted by schu4647 View Post
    Hi, schu
    1) note most of the the inputs have clamp diodes to VDD and VSS ... ( Hi , Charles ...)
    sooo ... not less than - .6 volts ...
    2) min Detection time of Pic® pins is 50 ns ...
