picbasic pro problem
Results 1 to 2 of 2
    Aug 2007
    Default picbasic pro problem
    HI to all!
    I did worked with microcode studio and pbp allready, there was some time I didn't and now would like to get back to it again....
    So I did take my PIC16F877, programmer and go to play, I did make simple code for 16F877:
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTD
    DEFINE LCD_RSBIT 1
    DEFINE LCD_EREG PORTD
    DEFINE LCD_EBIT 0
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    LCDOUT $FE, $C0
    LCDOUT $FE, 1, "Hello"
    than I get MSCMonitor red line on MCSNext....don't know why?
    I tried newer version os PBP, than everything is okay, except when I program PIC I don't get anything on LCD....
    Now, everything is connected okay and definitions are okay....when I program PIC with HEX i have it works, I also have source code of that HEX, when I try to compile it, it works and I get HEX, but when I program PIC with that hex it don't work.....and when I compare HEX i have compiled and when I do compile now they are different.
    Can you tell what would cause pbp compile program but it won't work....?
    Jul 2008
    TURKIYE-KONYA
    there will be many reasons.
    i think the problem is about your config settings.
    compare the orginal .hex file configurations with your new .hex file.
