cancelling gosubs
Results 1 to 18 of 18
    New Hampshire
    Default cancelling gosubs
    Hi all,
    I hate asking stupid questions so I beg forgiveness if this is one of them...
    Using Picbasic Pro... if I "gosub" and then wind up somewhere in the program where I need to "goto", is there a simple way to break the chain of gosubs and start anew? Can gosubs be cancelled?
    I hope this question made sense. Slap me if I need it. :-P
    Ross
    Never enough knowledge to be called intelligent but just enough knowledge to be considered dangerous!
    I like that! :-)
    SLAP!
    i don't understand what you need to do ... sorry
    New Hampshire
    do this
    do that
    gosub here
    Here:
    if do_dat_squat then goto there
    do this
    do that
    There:
    do this
    do that
    If the "IF" statement is true then the program winds up going back to "MAIN". Does the program think it is still nested in a subroutine?
    If so, can the nested subroutines be cleared?
    I needed the slap. *-)
    Ross
    I like that! :-)
    yes... but in this case why not changing you if then goto to a if then gosub... that will fix it.
    but in case you don't want to do what is next t your if then, i suggest you to set a flag to avoid this.. something like
    VoidStatementsNextToIF = 0
         do this
         do that
         gosub here
    Here:
         if do_dat_squat then Gosub There
         IF VoidStatementsNextToIF=0 then
              do this
              do that
    There:
         VoidStatementsNextToIF = 1
         do this
         do that
    Sep 2003
    Vermont
    I'd say don't do another Gosub, but do a goto as you have it. When you are done with that code, just insert a Return. It'll take you right back to main. Keep in mind, a Return from any subroutine will take you back to the last Gosub + 1 line.
    Hope this helps,
    Ron
    USA - Arizona
    Remember that you can only nests gosubs as long as you have a stack to do so. If you nest gosubs deeper than your stack (which is only 4-8 levels in many cases, and you need to save some if your use interrupts) you will crash your PIC.
    I would say, unless you have to use gosubs, don't. If you have to nest gosubs many levels deep, you should look for a different approach.
    Just my two cents.
    Warrier's Avatar
    Warrier Guest
    Hi all:
    Am I missing something and need a slap also?
    Why can't the following work?
    do this
    do that
    gosub here
    Here:
    if do_dat_squat then there
    do this
    do that
    There:
    do this
    do that
    This will close the gosub in either case of Here & There and take the routine to main which is the gosub+1 location....
    -warrier
    New Hampshire
    Default Knew I was opening a can of worms...
    Warrier,
    Yep that would do it alright... if... you wanted to return to the line following the gosub.
    My initial question was can you break out of a gosub nest... can the gosub be canceled such that a "return" would go nowhere. And from the replys I am getting that you can't.
    That being said, if... while nested in a subroutine... the program comes across the original gosub... it does not cancel the original subroutine... rather it increments the stack count by one.
    Such as...
    gosub here
    Here:
    if this goto Main
    do that
    If this is true, the gosubs loop until they violate the stack count and the pic crashes (he purses his lips and makes a pffrrgghh sound). I love sound effects.
    I can write code to get around things alright, but I wanted to just cancel where I was in subroutine and go back to "Main"... not "Return" to the next line following the "gosub".
    Ross
    I like that! :-)
    Nov 2004
    Fribourg, Switzerland
    Hi All,
    Answering your question (rosfree) about the clearing nested subroutines, the answer is no. The subroutines can't be cleared what you have to do is set a lot of flags or just review all your algorithm to fit your needs.
    Some time ago I had a problem with nested gosubs and had to use goto's mixed with gosub's it was a pain to figure out how to do that and I had to rewrite all the program. So my sugestion is: Stop and check all your needs before start writing your code. Check the manual for compiler limitations. It will save you a lot of time.
    do this
    do that
    gosub here
    Here:
    do this
    do that
    There:
    do this
    do that
    What you can do is setting a flag and testing it so instead of using the "goto main" you just use the "return".
    do this
    do that
    gosub here
    Here:
    flag=1
    goto there
    do this
    do that
    There:
    do this
    do that
    if flag=1
    flag=0
    I'm not sure what are your needs but this is not a real good programming technique and it can spend a lot of space in programs memory (it will depend on how the compiler translate it).
    Will you call the "There" routine in other parts of the program? if not and if you didn't use all the stack with nested gosubs, the best way is to call the routine or just follow Mister_e example that saves you a lot of trouble.
    Hope this help.
    Hans
    Warrier's Avatar
    Warrier Guest
    Ross:
    I think you can break out of a gosub using the BREAK command and NOT return to the gosub+1 line of the code!
    I've tried this a few times in the past but haven't tried to see if there would be a stack overflow problem and genarate the sound effect you're so fond of!
    -warrier
    New Hampshire
    Default break, breaking or broken...
    Warrier,
    I'm familiar with broken... but not with break.
    Is there such a command in PicBasic Pro or is this where I just toss the board and all of it's assundries out the two-story window?
    I don't know assembler so if that's where this command comes from can you provide a bit more detail on it's use?
    Window open... circuitboard in hand... *pause*
    Ross
    I like that! :-)
    Warrier's Avatar
    Warrier Guest
    Ross:
    I have used the break command and PBP seems to accept this without the in-line @ for assembler! But I don't see it listed in the manual..... break seems to clear the gosub from the stack.
    Melanie or Steve can come here and help?
    -warrier
    USA - Arizona
    Sorry to break your bubble guys, but the gosub/stack limitation has nothing to do with PBP.
    The PICs do not have a way of 'POPing' the stack (hey, they're extremely powerful for their size - something's gotta give). A GOSUB is no more than a CALL in assembly. When a CALL is made the next address is 'PUSHed' into the stack, when the RETURN is encountered the stack is 'POPed'. So you see, without any other way of 'POPing' the stack you will overflow if you keep nesting GOSUBs.
    Not to worry though, amazing programs have been made with these little devices for more than a decade. Just have to be more careful and a little creative.
    i agree.
    Your program must have a structure to avoid breaking gosubs... not a common used to do that. Sometime some goto,branch and FLAG variable will do the job. That's once again food for brain cells...
    always keep in mind of what you do and how it's suppose to work.... do a structured program. If your a 'Visual' kind of people, you can figure all your program using a kind of flowchart.
    New Hampshire
    Thanks all,
    Sometimes I want to program like I think. It's a bit frightening!
    Did you get it?
    BIT... Frightening!???
    *** he shudders***
    I wanted a definite answer on canceling GOSUBs and I think I got it. I can work around my needs in code no problem. Just wanted to know if it could be done.
    I could just hear that "POPing" sound Languer. Good sound! :-)
    As always, this forum rocks!
    Thanks again for the many replys,
    Ross
    I like that! :-)
    Hi Ross. I think I understand your question. If you gosub, the gosub will cancel if it doesn't reach the end line that says return. For example:
    gosub lightled
    lightled:
    if porta.1 = 0 then turnonmotor 'jump out if motor switch is closed
    high portb.1 'light up led on port
    turnonmotor:
    high portb.2 'turn on motor driver transistor
    goto motorcontrol 'go to a completely different area in program
    your gosub cancelled as soon as it went to turnonmotor and avoided the return line. Hope this helps.
    New Hampshire
    Hi Peter,
    Thanks for your reply.
    If you GOSUB in a program, then you must have a RETURN... or you will still be in a GOSUB stack. You can divert the program to go do something else as you have stated... but you are effectively still in the GOSUB.
    Sorta like leaving the toilette seat up in a house full of women. It can be done but I wouldn't recommend it.
    My original question was "could I put the toilette seat down with a remote control" (so I wouldn't have to walk back to the bathroom).
    or maybe it was...
    could I GOSUB... then from somewhere else in the program... CANCEL the GOSUB (so I wouldn't have to RETURN to the line following the GOSUB). Diverting to another part of the program is still effectively leaving the GOSUB (toilette seat) open.
    Thanks again for your reply...
    Ross
    ...a remotely controlled 'johnny seat'... There's a product there somewhere. Probably need a safety switch... or... NOT. **evil laugh**
    I like that! :-)
    Nov 2004
    Smile Software Stack
    Hi All,
    I was sniffing the net and I have found a quite interesting stack subroutine that the authors claims to let PBP do up to 48 nested gosubs.
    The url is:
    http://www.pbpgroup.com/modules/wfse...p?articleid=14
    I haven't tested so I can't say if it really works or not but if it does , it's quite an improvement to write more structured programs.
    Hope it can help.
    Hans
  1. cancelling a GOSUB without RETURN
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 7th March 2007, 15:30
  2. variables and gosubs???
    By guest_05 in forum mel PIC BASIC Pro
    Last Post: - 19th November 2006, 03:46
  3. GoSub Problem
    By ghoot in forum mel PIC BASIC Pro
    Last Post: - 11th May 2004, 16:15
