Help with code
Results 1 to 8 of 8
Thread: Help with code
    Question Help with code
    Hello, the code is :
    '// PIC 16F877A
    ADCON1=7
    CMCON=7
    OPTION_REG=%00000111
    TRISA=%111111 : TRISE=%111
    TRISB=0 : PORTB=0
    TRISC=%10001111 : PORTC=0
    TRISD=%00000011 : PORTD=0
    CCP1CON=0
    @ ERRORLEVEL -306
    B VAR BYTE
    C VARY BYTE
    D VAR BYTE
    		B=PortB : C[0]=PortC.5
    		for q=2 to 7
    			D[q]=PortD[q]
    		next q
    	IF B=0 and C=0 and D=0 then
    		toggle BUZ: pause 20
    As you can see I am trying to load ports into the variables. All ports above are outputs.
    The problem:
    When any of portB is made high in the main program then buzzer is off, as it should be, same is true for portc.5, but PortD is not being read properly. Even if lets say I make PortD.2 to D.7 high, one by one in the code for lets say 2 sec each (2 sec high/ 2 sec low) the buzzer is toggling non-stop. Though it should only toggle during 2 sec Low period.
    Can someone help please? Thanks
    ___________________
    WHY things get boring when they work just fine?
    Post
    Hi Finance
    1) C VARY Byte
    2) Your program loops ... only because there's no END in the END ... and program counter continues to count, overflows, then program restarts @ address 0000 ...
    That's why Buzzer toggles ...
    Question
    Thanks for the reply. Sorry it was a typing mistake @ vary
    This is not my full code. My actual code runs fine with reading port c.5 & Port B.
    My problem is correctly reading Port D.2 to D.7 into variable D. and if any of the pin is high, the buzzer should NOT toggle.
    But for some reason Variable D=0 is true even if Lets say PortD.2 or D.3 to D.7 is high i.e.=1
    I picked important lines from my code to explain the Problem.
    Is there any other way which can load PortD.2 to D.7 into variable D?
    ___________________
    Wink
    Ok
    so ...
    reading PORTD ...
    B=PortB : C=PortC.5
    D = PORTD & %11111100 ' read PORTD and mask port D.0 and D.1
    should fit ... no indexing necessary !
    ( BTW ... not sure it was working so fine ... lol )
    Thanks a lot. Problem solved.
    ___________________
    Question 1 MOre Problem
    This time the problem is with 16F676. While compiling I get the following errors
    ERROR: Unable to fit variable RM2_Save
    ERROR: Unable to fit variable RR1_Save
    ERROR: Unable to fit variable RR2_Save
    ERROR: Unable to fit variable RS1_Save
    ERROR: Unable to fit variable RS2_Save
    I am using DT-Interrupts in this code. Can some1 help me to get rid of these problems and what can I comment out in the ReEnterPBP or the other DT_INTS-14. Thanks
    ___________________
    Question
    The only thing I am doing in the ISR is the following:
    ToggleLEDF:
         If F1=1 then Toggle PortA.0
         If F2=1 then Toggle PortA.1
         If F3=1 then Toggle PortA.2
    @ INT_RETURN
    '---[TMR2 - interrupt handler]--------------------------------------------------
    ToggleLEDS:
         If S1=1 then Toggle PortA.0
         If S2=1 then Toggle PortA.1
         If S3=1 then Toggle PortA.2
    @ INT_RETURN
    ___________________
    Wink too small a RAM !!!
    Sure 64 Bytes of SRAM is a bit weak to handle DT-Interrupts ....
    Try to spare (re-use ) 5 of your byte variables ... may be you can re-use B,C,D and two other temporary variables elsewhere in your Program ...
    @ first C can be declared as a BIT ... probably others too ...
    Or change for a Wider RAM Chip
    Or Ask Darrel for a "Fast Interrupt" Option saving only the " live " registers and letting you choose which variables really need to be saved ... such C " #pragma disablecontexsaving " directive ( I'd love such an option !!! )
