GPS module + PIC
Results 1 to 13 of 13
    At what level is the Serial input of the PIC when you disconnect the GPS module? I guess the timeout is blocked by the incorrect level.
    You should have a pull up resistor there.
    SWITZERLAND (french speaking)
    Default It's working... yes and no
    I have tried both a 10k pull-down and pull-up resistor.
    I was thinking a pull-down would be correct since the PIC gets a "true" signal, but as it didn't work, I tried the pull-up way; no success
    Meanwhile, I have seen that the GPS module will always send the string my SERIN2 command is waiting for ("$GPVTG").
    If the module has no signal (no satellite coverage), it will still send the NMEA sentence with empty data, just like this "$GPVTG,,T,0,M,,N,,K*xx".
    So, if I disconnect the GPS from the PIC, it works but... it is not the way I would like to have it working.
    Roger
